2006 V70 base, auto. Timing belt change tomorrow. Water pump will be changed as well. Accordingly, coolant gets drained. I won't be able to pick up Volvo coolant between now and tomorrow morning.
Any recommendation on preferred coolant? My mechanic will use universal/green if I don't supply my own coolant. I was thinking along the lines of G5. What's best alternative to Volvo brand coolant?
Thanks.
Coolant -- Need Brand Recommendation
- E Showell
- Year and Model: ‘07 S80 3.2
- Has thanked: 37 times
- Been thanked: 112 times
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'02 Honda Insight CVT
‘06 Honda Insight CVT
'95 855 auto (sold)
- Has thanked: 1613 times
- Been thanked: 4077 times
Pentosin blue stuff is what I use.
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
I'd rather fill with the Prestone Radiator Flush+Cleaner plus a few gallons of distilled water and drive gently for a few days, then rinse with distilled water, then fill with Volvo coolant ($25) + dw. It is a good start not knowing what was in there before. I just did this because I didn't get enough cabin heat in winter, now it blows at 180F
- E Showell
Pretty sure I've got Volvo coolant in there now. Have to go with what's available at the commercial auto parts stores in the near term -- probably opting for G5. I don't want to put new coolant in then replace in a few weeks' time with Volvo coolant. I hate dealing with coolant. It's a feel thing. I dislike the greasy/slippery aspect of it. Plus disposing of used coolant is a bit of a hassle.
'95 855 auto (sold)
'95 855 auto (sold)
If you have sewers most muni allow disposal of personal amounts down the drain. Check with your local muni for their regs. Glycol breaks down in a week or two.
Nitrile gloves are the first thing I put on when I mechanic , nowadays.
- BlackBart
- Has thanked: 967 times
- Been thanked: 923 times
Ooo..not here!abscate wrote: 12 Jul 2018, 04:30 If you have sewers most muni allow disposal of personal amounts down the drain.
Yes on those gloves. Unless it's above 85 in the garage!
- E Showell
Valvoline HOAT was what was available. That's what I'll be using unless someone gives me a good reason not to between now and tomorrow morning.
'95 855 auto (sold)
'95 855 auto (sold)
Georgeandkira
- Year and Model: '07 V70 + '15 XC70
- Has thanked: 80 times
- Been thanked: 71 times
You can plan a timing belt change and not have time to order a jug of Volvo coolant online?
- 1205 Views
Last post by nyc1836
- 8541 Views
Last post by precopster
- 1675 Views
- 12 Replies
- 1339 Views
Last post by June
- 1442 Views
Last post by balabaika
