Thermostat Housing
VolvoAffair
Year and Model: 1998 S70
Been thanked: 4 times
Post by VolvoAffair »
Cracked the thermostat housing during my head install. Yes, I was using a torque wrench and still cracked it. :roll:
As such, I need a replacement for my 98 s70 T5
Thanks!
RickHaleParker
Been thanked: 978 times
Post by RickHaleParker »
Did you clean the mating surfaces good and torque the bolts in stages?
Engine cooling thermostat housing is Volvo part number 9447995.
  • Volvo C70 2.3l 5 cylinder Turbo Convertible 1998, 1999, 2000, 2001, 2002, 2003, 2004
    Volvo C70 2.3l 5 cylinder Turbo Coupe 1998, 1999, 2000, 2001, 2002
    Volvo C70 2.4l 5 cylinder Convertible 2000
    Volvo C70 2.4l 5 cylinder Turbo Convertible 2000, 2001, 2002, 2003, 2004
    Volvo C70 2.4l 5 cylinder Turbo Coupe 2000, 2001
    Volvo C70 2.5l 5 cylinder Turbo Convertible 1998, 1999
    Volvo C70 2.5l 5 cylinder Turbo Coupe 1998, 1999
    Volvo S70 2.3l 5 cylinder Turbo 1998, 1999, 2000
    Volvo S70 2.4l 5 cylinder 2000
    Volvo S70 2.4l 5 cylinder Turbo 2000
    Volvo S70 2.5l 5 cylinder 1999
    Volvo S70 2.5l 5 cylinder Fuel Injected 1998
    Volvo S70 2.5l 5 cylinder Turbo 1998, 1999
    Volvo V70 2.3l 5 cylinder Turbo 1998, 1999, 2000
    Volvo V70 2.4l 5 cylinder 2000
    Volvo V70 2.4l 5 cylinder Turbo 2000
    Volvo V70 2.5l 5 cylinder 1999
    Volvo V70 2.5l 5 cylinder Fuel Injected 1998
    Volvo V70 2.5l 5 cylinder Turbo 1998, 1999
    Volvo V70 XC 2.4l 5 cylinder Turbo 2000
    Volvo V70 XC 2.5l 5 cylinder Turbo 1998, 1999
Oil cooling thermostat housing is Volvo part number 3528199.
  • Volvo 850 2.3l 5 cylinder Fuel Injected Turbo 1994, 1995, 1996, 1997
    Volvo 850 2.3l 5 cylinder Turbo 1995, 1996, 1997
    Volvo 850 2.5l 5 cylinder Turbo 1997
Active
Past
Has thanked: 311 times
Been thanked: 817 times
Post by erikv11 »
Your go-to part here is a thermostat housing from any 94-98 850 or x70. Turbo or non-turbo or AWD or body style you can ignore, none of that matters. The RN heads (99 -onward) may or may not fit, I'm not sure.
It's a head install, he's not talking about the oil cooler thermostat.
amblerman
Year and Model: 1999 s70
Has thanked: 2 times
Been thanked: 70 times
Post by amblerman »
VolvoAffair
I sent you a PM on this subject.
-A
