IPD sale Volvo Parts
2006 V70 Intermittent Central Locking driver rear door 30784980 Topic is solved
Help, Advice, Owners' Discussion and DIY Tutorials on Volvo's stylish, distinctive "P2" cars.
2001 - 2007 XC-70
a3inverter
Year and Model: 2006 V70
United States of America
Post by a3inverter » Thu Jul 12, 2018 6:33 am
All,
On my 2006 V70 I have an issue where the driver side rear lock won't lock when the central locking button on the driver's side door is depressed OR when I use the key fob lock button. Once this happens, the central locking from the CLB functionality is disabled.
This is intermittent - usually every 5 or 6 times I lock/unlock. I can get it to start working again with a combination of manually locking and unlocking but it's a pain and makes me long for a car with manual locks (and ones where the rear door lock was positioned at the front of the door for each reaching :))
My reading suggests that this is either due to 1) some issue with the wiring harness as it enters the door or 2) the thermal fuse in the door lock actuator. I was going to explore both of these this weekend, but would like to understand if I need to disconnect the battery and if so, what the proper procedure is to avoid the dreaded SRS messaging that can only be reset by the dealership (or someone with VIDA/DICE).
Also, feel free to tell me if I'm barking up the wrong tree on this one.
a3inverter
Re: Intermittent Central Locking
Post by a3inverter » Thu Jul 12, 2018 6:10 pm
Update: Locking and unlocking the problematic door resets the situation. Until it happens again, then again, the manual method fixes it. So, all signs point to the drivers rear door module? Doesn't really sound like a thermal fuse issue...but I'm not an expert.
Year and Model: 1999 V70T5, 2005 V70
Has thanked: 130 times
Been thanked: 402 times
Trinidad & Tobago
Post by abscate » Fri Jul 13, 2018 3:14 am
I think I’m having this trouble on my 99 with the passenger door, so I’ll use this thread to troubleshoot, too
Actually, I won't. P80 99 and P2 completely different. Sorry for the noise, carry on.
1 SWMBO for 30 years
2 Volvos
3 VWs
4 Careers
5 cats/dogs/gears
6 Perfect Ladies in waiting
7 Drivers
8 Boats- with a big pointy metal thing on top
1999 V70 T5M 56 2005 V70 NA M56 VWs BMW
93SCMax
Year and Model: 2001 V70 T5
Been thanked: 4 times
Post by 93SCMax » Fri Jul 13, 2018 5:55 am
I had this problem a few years back with my 2001. Same door. Replace the door lock actuator. I used a junk yard replacement. Still working great.
Don't forget to disconnect the battery prior to replacing, and use the re-install battery procedure so that the key fob, sunroof, etc. get reinitialized properly.
Good luck.
Added proper battery disconnect/reconnect procedure courtesy of Howardsvolvo:
http://howardsvolvos.webs.com/miscissues.htm#207347288
a3inverter
Post by a3inverter » Fri Jul 13, 2018 8:13 am
Excellent. That was what I figured was the canonical reference for the procedure.
a3inverter
Post by a3inverter » Sat Jul 14, 2018 4:20 pm
Update: Got a door lock actuator out of a 2004 XC70 at the salvage yard and installed it. It's been working so far (longer than it would take for the old one to go into its failure mode) Pretty straightforward to install. I like the old style door clips better than the new (old had a center pin about 1/8" in diameter whereas the newer style is probably 1/16" - had to grind off the tip of a nail and use that). The only tricky part was where the rod from the exterior door handle gets clipped in.
a3inverter
Post by a3inverter » Sat Jul 14, 2018 4:21 pm
And...I followed the HowardsVolvo instructions for disconnecting/reconnecting the battery and all went according to plan. Thanks all!
93SCMax
Post by 93SCMax » Sat Jul 14, 2018 5:35 pm
Glad you got your issue resolved!
Trinidad & Tobago
Re: 2006 V70 Intermittent Central Locking driver rear door
Post by abscate » Tue Jul 17, 2018 4:59 am
A3 can you put the part number of the module into the first post title please?
Also, would love some inverted A3 pictures
2 Volvos
3 VWs
4 Careers
5 cats/dogs/gears
7 Drivers
a3inverter
Post by a3inverter » Tue Jul 17, 2018 6:26 am
The handle is not what you think :)
The door module is...in the door so part number is obscured.
If we are to believe the FCP cross reference, a wide range of years can supply the appropriate part:
https://www.fcpeuro.com/products/volvo- ... 80#fitment
In this case, I grabbed one from a 2004 XC70. The only difference I could see was that the 2004 exterior door clip was blue and mine was black.
If I find myself with some extra time, I may investigate the one I replaced to find the cause of the issue.
Who is online
Users browsing this forum: chrism, EngineeringBloke, XC70Rider and 41 guests
