Hello, 6-month 2000 S40 1.9T owner here. The car has been leaking some oil from the back of the engine somewhere I can't see since I got it. I assumed that it is the turbocharger but didn't address it because it was a small amount of oil. Today is a hot day (90F). I got on the freeway and when I got up to speed and let off the gas I noticed that after a moment, the car would suddenly start slowing down much more quickly than air drag would cause (it felt like a Prius's regenerative braking). If I kept my foot on the pedal it felt like I had to push it down further to maintain speed.
I pulled over and listened to the engine and it sounded normal. I checked the coolant and oil. The coolant was at a normal level, but the oil was close to the low mark. I checked the oil yesterday and it was half a quart higher. I noticed that a lot more oil was leaking and creating some smoke on the tailpipe. At this point I assumed that the turbo was probably seized and leaking so I added some oil and went home.
Now I've been reading up on symptoms of a failed turbo and it seems like it should be making some noise, but it doesn't seem to be. I still can't figure out where the oil is coming from because it's covering all of that area. My main concern is the dragging issue, but I don't know if there's a connection with the leak worsening. I'm very confused, any ideas?
Thank you very much.
Engine "dragging" at closed throttle
Broodoobob
- Year and Model: 2000 S40 Sedan
Broodoobob
I was able to access the turbo and found out a couple things:
- The turbo is not seized, and turns very nicely with almost no wobble.
- There's no oil coming off of the turbo itself, but there was a small amount of oil inside the boost pipe
Broodoobob
Seems like the oil is coming from that turbo oil line. I'm guessing I just need to replace that red gasket.
I suspect that the turbo is a red herring on the dragging issue. There's no codes set but I'll check my ignition and compression in the morning to be sure.
- alschnertz
- Year and Model: 1995 854T
- Has thanked: 2 times
- Been thanked: 12 times
I think i'd check for excessive crankcase pressure before tackling the o-ring replacement.
Search "glove test".
'84 Prelude
'06 MPV
'13 Ford Focus SE
'84 Prelude
'06 MPV
'13 Ford Focus SE
jimmy57
- Has thanked: 5 times
- Been thanked: 322 times
Orange o rings are the problem ones, green will replace it.
If I get "dragging" right then I'd watch tach and see that it is in 4th and not third gear. I think you mean it slows aggressivley, as in lot more engine braking when you release throttle.
Broodoobob
Thanks guys. I did the glove test and it sucked the glove right in and wedged itself under the camshaft. Oops... Fortunately after turning over the engine one starter blip at a time I was able to pull it out in one piece. Regarding the gear, I did a road test today to see if it was staying in 3rd gear and it was definitely in 4th. In position 3 the RPMs were much higher.
I did a compression test today and compression was a bit low across the board, with the cylinders reading 137, 133, 142, and 130 when hot and dry. When I added some WD40 to the cylinders they read 170, 182, 170 and 138. Seems like cylinder 4 has a valve issue, but I'm not sure if that's new or the cause of the issue.
I picked up the parts for replacing the red o-ring today. I'm going to tackle it tomorrow but it's going to be a pretty miserable job. It looks like the turbo has to be unbolted and raised to access the torx bolts that hold on the pipe underneath which means draining the coolant. It seems like it was designed to increase labor...
Broodoobob
And yeah, the dragging feels a lot like engine braking, but the RPMs are low. I did try running it in neutral to confirm that it's an engine issue.
- alschnertz
So it did "freewheel" when you popped it into neutral?
Though your compression numbers are a little low, at least they're within acceptable tolerances of each other.
Are you sure about that #4 cyl.? Could your gauge have leaked?
I'm thinking that bad rings (indicated by your compression readings) would pressurize the crankcase, yet your glove test showed vacuum in the crankcase (which is normal).
Also, you would think that if you had bad compression, there would be less compression braking - not more.
This is a good puzzle.
'84 Prelude
'06 MPV
'13 Ford Focus SE
'84 Prelude
'06 MPV
'13 Ford Focus SE
Broodoobob
Good points, yeah. It did indeed properly freewheel in neutral. I double-checked my numbers on number 4 on a cold engine and they were consistent with the previous numbers so I believe they are correct. I replaced my oil seal yesterday which was a massive PITA but the oil leak is gone so that is nice. The main issue still remains though and I really have no idea what is causing it.
I've also noticed that my fuel economy has gone down from 27mpg to 21mpg.
- alschnertz
And those numbers were meh, ok. Since you didn't replicate the warm readings, I don't think I'd blame bad rings on cyl. 4 yet.Broodoobob wrote: 18 Jul 2018, 15:21I double-checked my numbers on number 4 on a cold engine and they were consistent with the previous numbers so I believe they are correct.
Drawing straws here so I'm thinking of going to Stage 0...
Have you checked the fuel pressure?
What did the spark plugs look like?
Inspect the coils with a magnifying glass.
Are the spark plug wires good?
Have the MAF, TB and IAC been cleaned?
Air filter is ok?
Codes?
How about if you switch the ignition off on deceleration. Does it feel the same as the "dragging"?
Just trying to isolate what the heck is going on.
'84 Prelude
'06 MPV
'13 Ford Focus SE
'84 Prelude
'06 MPV
'13 Ford Focus SE
- 1403 Views
Last post by Oly850
- 1220 Views
Last post by WaxhawFive
- 290 Views
Last post by JimBee
- 1424 Views
Last post by schoen951
- 3744 Views
Last post by BEJinFbk
