Current thinking on best axel boots?
JimBee
Has thanked: 25 times
Been thanked: 42 times
Post by JimBee »
I just noticed that the outer drivers side axle boot on my 93 850 manual is split and slinging grease. One more thing to repair before putting it back on the road in November.
Reviews on FCP axle boots vary from made of plastic and good for 2 years, to great, including fitment.
Rein boots seem commonly available. Has anyone had this brand installed for a while, or otherwise some knowledge about them?
Other brands?
I checked Tascaparts.com. They don't list boots as available for the 93 but do list them for 95.
https://www.tascaparts.com/oem-parts/vo ... wtbDUtZ2Fz
I've replaced one 10 years ago when I bought the car, but don't recall if the 93 was unique. Does anyone know?
misha
Year and Model: '97 850 2.5 20v
Has thanked: 152 times
Been thanked: 402 times
Post by misha »
GKN is what you need if you want them to last.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
RickHaleParker
Been thanked: 958 times
Post by RickHaleParker »
Nothing special for the 1993.
There is a Inner & outer boot, one each left and right.
Here is a Inner & Outer kit that fits your '93 manual for $23.19.
It is OEM Quality, guaranteed for life, for as long as you own the vehicle.
Here a Genuine Volvo, same part number as Tasca for less.
850 fitment
1993 Volvo 850 GLT 2.4L L5 Axle Boot Kit
Transmission control type: Standard, Position: Inner and Outer
1994 Volvo 850 Base 2.4L L5 Axle Boot Kit
1994 Volvo 850 GLT 2.4L L5 Axle Boot Kit
1995 Volvo 850 Base 2.4L L5 Axle Boot Kit
1995 Volvo 850 GLT 2.4L L5 Axle Boot Kit
1996 Volvo 850 Base 2.4L L5 Axle Boot Kit
1996 Volvo 850 GLT 2.4L L5 Axle Boot Kit
1997 Volvo 850 Base 2.4L L5 Axle Boot Kit
Has thanked: 1846 times
Been thanked: 1710 times
I would only use Volvo OE or GKN (OEM) branded parts unless you like do-overs on work in a short time.
JimBee
Post by JimBee »
Thanks for the info. FCP lists the "genuine Volvo" parts number, but seems to indicate it's a Rein product. I'll call them tomorrow to clarify.
sleddriver
Year and Model: 1998 V70 T5
Has thanked: 11 times
Been thanked: 12 times
Post by sleddriver »
I wouldn't use Rein. Search my thread on front axle removal to do boots! The passenger outer tore (may have hit something?!). I've been putting it off though I do have a GKN boot.
M1 10W-30 HM
Has thanked: 292 times
Been thanked: 765 times
Post by erikv11 »
Eek, definitely do not use Rein CV boots unless you are excited to know you will be pulling the axle again soon. It's been checked out thoroughly on the forum, they do not last. GKN is the only way to go.
Sorry also I don't know if the 93 uses a different boot. You'll have to trust the online sources that say they are the same, that usually works out.
'06 S60 R, 197k
'07 XC70, willow green, 212k
'99 Camry V6 :shock: 153k
