V70R dumping coolant immediately after turning car off
diplomaticm3
Year and Model: 2004 xc70
Has thanked: 1 time
Post by diplomaticm3 »
Weird issue...the car is basically dumping coolant immediately after turning the car off. It’s super hot here in Texas obvi...but still weird.
I’m thinking a crack in the coolant reservoir?
Has thanked: 2197 times
Been thanked: 1851 times
It could be that or a bad pressure cap. They also crack or fail
Dmck
Year and Model: 1995 850
Has thanked: 2 times
Been thanked: 3 times
Post by Dmck »
The may sound dumb but where is it dumping coolant from?
diplomaticm3
Has thanked: 1 time
I believe it’s leaking from the tank bc when I turn the car off & pop the hood, the reservoir is gurgling fluid and there’s a big puddle underneath the car at that location.
Has thanked: 1609 times
Been thanked: 4064 times
Track down the leak. Your pressure does spike after a hot run so this isn’t that unusual an occurrence.
The reservoirs live about 12 years, the caps maybe 1/2 that
Be careful removing the tank and remember to lift it just a few cm, then disconnect the sensor underneath before it breaks
Dmck
Post by Dmck »
Both tank and the lid can be bought reasonably on the internet.
The worse case scenario is a head gasket leak which can push cylinder pressure and exhaust into the coolant in the engine.
Gets some soapy water and rub down or spray the tank do the same for the cap.
Turn on car until the radiator fan starts running. This will give best idea because you have allowed the car to heat up.
Look for bubbles from the soapy water to find cracks in the tank, lid, or possibly from the connecting coolant hoses.
