P80 AC ORings Tabulation, condensor Orings NLA? (1993-1999 AC)
Has thanked: 1609 times
Been thanked: 4063 times
Ive found a couple of Orings on the P80 1999 no longer listed at major parts places
Oring for fill valve NLA? Fill valve is 6849305 - maybe comes with Oring
Condensor pipe to condensor hard line - NLA
Condensor to condensor pipe/compressor NLA
The comprehensive list of O rings on the AC system, 1999
Using Volvo Parts Lisle as guide
http://volvopartslisle.com/assembly/790 ... nditioning
Added sizes per reference from EEuro site
Oring - evaporator cold side 3545416 2 on this line (4 total in system,15x11mm)
Oring Evaporator warm side 988840 2 on line this line (3 total in system)
Oring on pressostat valve (low pressure) 3537501 Qty 1 (12x8mm)
Orfice valve - downstream Oring 3537797 (9x5.5mm) Qty 1 - this one comes with a new orifice valve
Orfice Valve upstream 988840 one on valve, comes with new valve (total 3 in system)
Oring between condensor and hard lines 9883337 qty 3 total in system
Oring from condenser pipe to compressor 6847526 (21x16mm)
Oring to compressor suction pipe 354441 (24.5x20)
ORing from suction pipe to drier 9888433 (16.5x12mm)
Oring from drier to hard line/evap warm side 3545416 2 at this location, 4 in system
RickHaleParker
Been thanked: 977 times
Post by RickHaleParker »
Kit said to contain all of the o-rings to seal the A/C connections on a single car.
Santech Part Number 307598124
1998-2004 Volvo C70
1998-2000 Volvo S70
1998-2007 Volvo V70
2003-2007 Volvo XC70
Active
Past
That kit is definitely short 4 o rings, and I think it is the same one FCP sells, which did not have all the ones we needed on our 99.
From a recent 1999 AC overhaul, we used the Santech MT2673 Oring kit and were short
one evap line cold side oRing
One evap line warm side oRing
Drier to condenser hose Oring
Compressor suction hose to drier Oring
Year and Model: Many Volvos
Been thanked: 76 times
Post by Ozark Lee »
If you take the old one in to a NAPA they should be able to match them. There really isn't anything special about them so long as they are rated for PAG oil and pretty much all of them are.
Ozark Lee wrote: 30 Jul 2018, 15:09 If you take the old one in to a NAPA they should be able to match them. There really isn't anything special about them so long as they are rated for PAG oil and pretty much all of them are.
Old thread , adding knowledge
HNBR are the type of orings you want to use on air conditioning systems with PAG oil
