Modifications for more legroom
a3inverter
Year and Model: 2006 V70
Been thanked: 9 times
Post by a3inverter »
All,
Wondering if any of you taller (6'4" here and mostly legs) drivers have done any successful modifications to your drivers seat to squeeze out a bit more legroom. When I got my e39, there was a clip that acted as a limit stop on the travel - I removed that and got another inch of room. The center console in the e39 is also lower and the parking brake handle is in a different location and allows me to lean my knee more towards it. At present, rides over 20 minutes or so in the V70 cause a level of knee discomfort
Part #8 in this diagram might be something to focus on, but I think it might just govern forward travel of the seat.
http://volvopartslisle.com/media/diagram/GR-383301.png
The rear end of the rods along which the motors act appear to have a second hole in the back just forward of the hole the mounting screw goes through. Not sure how the front is secured and the diagram above doesn't reveal the secret.
Any thoughts?
Thanks!
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
A good way to find an answer is to try at a junkyard. I haven't read of such mod on the S60, but I also miss 2-3in if it was to really stretch my legs like I was doing in a VW Passat (I'm 6'1 with rather long legs). Obviously lowering the seat helps the most here but to stretch the legs on a long trip, the S80 is the actual answer.
a3inverter
Did some investigating this morning. I think I can gain an inch more in the rearward direction if I move the bracket back (will need to move the threaded rod back a bit too. There's about 1/4" of length at the front end of the rod.
Seat Mods.png (1.32 MiB) Viewed 3183 times
Rattnalle
Year and Model: 2004 V70 2.5T
Has thanked: 20 times
Been thanked: 133 times
Post by Rattnalle »
oragex wrote: 01 Aug 2018, 06:29 A good way to find an answer is to try at a junkyard. I haven't read of such mod on the S60, but I also miss 2-3in if it was to really stretch my legs like I was doing in a VW Passat (I'm 6'1 with rather long legs). Obviously lowering the seat helps the most here but to stretch the legs on a long trip, the S80 is the actual answer.
Having the seat higher helps much more than lowering it to me. Makes the leg position more relaxed and less sitting on the floor with the legs straight forward.
I'm 6' with a 36" inseam measured down to the floor when standing and I've got several inches to spare when it comes to seat adjustment. I can't reach the pedals comfortably without stretching if I move the seat all the way back. Perhaps the manual seats can be moved further back?
a3inverter
Agree on the height as well as I think knee angle is critical to avoidance of knee discomfort. More experimentation is necessary. I think I can use the threaded coupler trick on the front up/down adjustment as well. Guess I'm hitting the junkyard this weekend :)
My e39 doesn't have a "hanging" accelerator like the Volvo does so I can tilt my right foot to the right and get to a comfortable position (this also means tilting my knee to the right which the console in the Volvo prevents me from doing to the extent that I need).
oragex
Post by oragex »
I also agree about the higher the seat, the better the comfort for taller persons. My favorite seats are the ones in some minivans and SUV with rise seats.
That's a good call on manual seats, they may be different
Has thanked: 1610 times
Been thanked: 4065 times
I’m 6-1 but only 32 inseam, I always running into the top of cars except for Volvo.
a3inverter
Update: I boosted the front of the seat with some HDPE blocks I fashioned for the purpose. A few weeks later I moved the threaded rods back by using the second unused hole in my first pic. This required that I extend the front end of the threaded rods about an inch. I used a barrel coupler and a like-threaded bolt to accomplish this. I seem to have arrived at a relatively comfortable position for the seat, however on longer highway drives I will use CRUISE and stretch my leg out by putting it between the pedals.
