IPD sale Volvo Parts
Motor Seized? Next steps?
Help, Advice, Owners' Discussion and DIY Tutorials on the current (third) generation Volvo V70 wagon and XC70 crossover, and second generation S80.
This is a forum for owners or prospective owners of the third generation V70, second generation S80, and its siblings built on the EUCD platform.
IronMike
Year and Model: 1999 S70 GLT
Has thanked: 3 times
Post by IronMike » Wed Aug 01, 2018 5:33 pm
'07 XC70 with 185k. Offspring called - stranded near home! Said all dash lights came on while driving and steering went stiff - so engine stopped while driving. Pulled over safe thank goodness.
Fresh battery, starter engages but doesn't turn the engine - or can't? Check the oil and YIKES just a bit on the tip. Add just over 3 quarts and that brings up to the bottom of the hash marks, so looks like it might have only had about 1 quart or so in the sump. Not good! Starter engages, all dash lights dim, trying several times doesn't budge motor though each time the crank moves a tiny bit. Then battery wires start to overheat, so stopped trying. So sad, just polished the headlights and replaces whole suspension. See oil coating on lower rear on passenger side, timing belt is dry.
All hope gone? What would you do for next steps to determine if truly "seized"?
What would an engine swap cost ya think? Worth it on a car with $3k or so book value? Just pondering options...paid $10k for this 2007 in 2013 with 125k on it, doesn't really owe us a dime, been a real workhorse but wife does love it...
ThommyKent
Year and Model: 91 245 97 850 T5
Romania
Re: Motor Seized? Next steps?
Post by ThommyKent » Thu Aug 02, 2018 1:00 am
Poor car died from neglect. It`s done. Buy a Prius
Rattnalle
Has thanked: 12 times
Been thanked: 87 times
Sweden
Post by Rattnalle » Thu Aug 02, 2018 1:45 am
Sounds like it yeah.
Take the passager wheel off and try turning the engine by hand using a socket on the crank pulley nut. It should turn relatively easy. If it doesn't the engine really is stuck and your only option is replacing it. Probably only worth it if you can do the work yourself.
IronMike
Post by IronMike » Thu Aug 02, 2018 6:41 am
Lets not get all judgey, there was oil in the engine 2 days before. Seems like over 2 days it lost over 3 quarts. Haven't even had a chance to get under it since getting it towed home. But I did try to crank it over this morning and it went about 4 (very strained, slowing each one) revolutions with a really nasty tenth of a second SCREEEECH every turn, and then stopped again. Never had a seized motor, would a loud SCREEEECH like that with every turn of the crank be something INTERNAL? Seems odd you'd hear it that loud. Or can main or cam bearings make a noise like that?
oragex
Year and Model: S60 2003
Has thanked: 74 times
Been thanked: 124 times
Canada
Post by oragex » Thu Aug 02, 2018 7:15 am
If it lost that much oil, perhaps an engine seal has gone - sometimes this is related to a badly clogged PCV system.
Timing belt seems to be well in place? How is the water pump? Some people put aftermarket wp which seems designed to sudden fail after 20-30000 miles or so.
A used engine swap is a decent $3000 but the problem is to get one that had it's PCV replaced in time (no latter than 120k miles)
2003 2.4i S60 automatic 125k miles
DIY Volvo repairs videos https://www.youtube.com/playlist?list=P ... s0FSVSOT_c
IronMike
Post by IronMike » Thu Aug 02, 2018 5:04 pm
Pulled plugs and removed serpentine belt and cranked engine. Same slow turning/straining for about 3 revolutions and then started speeding up. Then the engine started turning normal crank speed and oil light went out! Haven't put things back together yet, will be interesting. Wondering is sluggishness was drag from pistons in cylinders, cams, bearings, all...
IronMike
Post by IronMike » Thu Aug 02, 2018 5:08 pm
RE: Neglect, you are probably not far off. PCV was serviced late in the game by a dealer but I have a suspicion they only replaced the hose from oil trap/box to valve cover and didn't properly clean the port in the block. See how things go...
SuperHerman
Been thanked: 77 times
United States of America
Post by SuperHerman » Thu Aug 02, 2018 6:11 pm
What year XC70 are we talking about? The price you paid does not match a 2008 or newer unless you got a screaming deal back in 2013.
That said your engine prognosis is not great if the oil went dry. Scored cylinder walls and/or pistons, ruined rings and damaged bottom bearings. Now if the engine oil light was functioning properly (and was not on during the final event for very long) the lack of oil may not be the issue.
If you get it started and it is not knocking, smoking and making very sad noises check your oil by draining it and oil filter for metal sparkle - signs of ruined motor. After that if it checks out do a compression test - if you have serious damage your numbers will be really low.
Maybe a pulley on the serpentine belt seized or a/c seized and your oil was low.
difflock54
Year and Model: V40 Nordic 2002
New Zealand
Post by difflock54 » Thu Aug 02, 2018 7:21 pm
Having turned over slowly it clearly was not seized solid.
Now you have managed to turn over the motor with plugs out I'd try adding a teaspoon of oil into each cylinder for good measure.
Then turn it over again,still with plugs out to help getting some lubrication to the upper motor components.
After that and assuming you haven't found any major oil leak, top off the oil to the correct FULL level and then try starting her up.
You may be lucky and it will be ok? but well worth a shot as opposed to just writing the motor off outright at this stage.
IronMike
Post by IronMike » Fri Aug 03, 2018 6:03 am
'07, was a good deal since it was a dealer's loaner with higher miles but in decent shape and came with records. Timing belt kit installed just before we bought it. I'm going to do a compression test before I try to fire it up, might change the oil before firing it up as well, or at least the filter. All plugs looked good, we shall see...
Who is online
Users browsing this forum: No registered users and 4 guests
