94 850 n/a intermittent stall, crank no start
Dkherr
Year and Model: 1994 850 non turbo
Post by Dkherr »
Hey Everyone,
I’m new to the forum. I just recently purchased a 1994 Volvo 850 non turbo. It has 128,000 miles on it.
I don’t know too much about it’s mechanical history besides that the timing belt was done at 98k and the previous owner replaced the coolant temp sensor and thermostat.
I’ve had the car for about two months. I replaced the battery. It was shot. The car ran great up until a week ago. The car will randomly just shut off and then crank no start. If I wait an hour or so it will start back up again as if nothing happened. The idle seems to be ok.
I noticed the car still has the original 94 bougicord spark plug wires. I have no idea if anyone has ever done any maintenance on the vehicle.
Anyway, how should I proceed?
Dkherr
Post by Dkherr »
I forgot. There are no codes. I checked them yesterday.
RickHaleParker
Been thanked: 978 times
Post by RickHaleParker »
It does sound like you may have a intermittence in the electrical system.
Do a thorough inspection of the electrical wiring. Damaged wires that maybe shorting out. Dirty, corroded or loose connectors that maybe opening.
Active
Past
crlande
Year and Model: 240DL;850;S70
Has thanked: 1 time
Been thanked: 36 times
Post by crlande »
My 94 did same thing, also with no codes, until the camshaft position sensor was replaced. It is a silver cylindrical disk just aft of the cap and rotor. Check for corrosion on the connector first. It may not be the issue but is simple to look at.
Has thanked: 1610 times
Been thanked: 4065 times
You will have to wait for the nonstart and then make a snap diagnsosis to get the right branch on then diagnostic tree.
I suggest starting fluid to check for fuel delivery problems. A pro would put a fuel pressure gauge on the rail and confirm correct pressure
If you want to throw parts, fuel pump relay and ignition switch electrical part would be the top candidates
Things it isn’t....bad gas, plugged fuel filter, bad oxygen sensor, bad catalytic converter, or bad ECU
Dkherr
Post by Dkherr »
I put a new fuel pump relay in and I’ve had no issues for three days. We will have to see if it happens again.
