2006 V70 Oil Leak-- High on Block near timing belt end
E Showell
Year and Model: ‘07 S80 3.2
Has thanked: 37 times
Been thanked: 112 times
Post by E Showell »
I have an oil leak. Definitely not cam seals, but apparently high on block. Mechanic says coming from valve cover area, but specific location not pinpointed.
Oil regularly changed around every 3 K by prior owner, passed glove test on PCV system pre-purchase. No evidence of rear main seal leak, no apparent sludging, no codes, no diminished performance issues. Oil pooling near front (under crank pulley) engine mount.
Any idea what's going on here?
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'02 Honda Insight CVT
‘06 Honda Insight CVT
jonesg
Year and Model: 2004 V70
Has thanked: 73 times
Been thanked: 532 times
Post by jonesg »
Does it have cvvt cam solenoids, they can leak. I'd clean it up good and watch where it comes from.
Check spark plug wells.
Install new oil seal on the oil fill cap.
E Showell
Post by E Showell »
Not sure about the CVVT -- it is a 2006 base V70 non-turbo.
'95 855 auto (sold)
Has thanked: 311 times
Been thanked: 817 times
Post by erikv11 »
Oil cap seal or PCV hose from the oil trap to the nipple on top of the cam cover. Both are common, oil cap more so, either one drains to the pass side once the oil pools up on top.
E Showell
Post by E Showell »
I'll change the oil filler cap seal, but I think it's leaking more than that.
'95 855 auto (sold)
Has thanked: 1609 times
Been thanked: 4065 times
CVVT Intake if it is like 2005. There is a lot of oil flowing there, so that is where I would look.
