2002 Volvo S40 Trunk wont open after battery change?
mountaincarjunkie
Year and Model: 2002 Volvo S40 1.9T
Post by mountaincarjunkie »
Title. After I changed the battery the trunk wont open with the key or the faab. Any ides? The glove box isnt locked.
alschnertz
Year and Model: 1995 854T
Has thanked: 2 times
Been thanked: 12 times
Post by alschnertz »
The car battery or the fob battery?
'84 Prelude
'06 MPV
'13 Ford Focus SE
mountaincarjunkie
alschnertz wrote: 09 Aug 2018, 19:38 The car battery or the fob battery?
The car battery.
alschnertz
The key doesn't actually open the trunk on my '01.
All the key does is manually enable or disable the push button latch.
As for why your fob isn't working, maybe it's coincidental. Maybe it'd be worth changing the fob battery.
'84 Prelude
'06 MPV
'13 Ford Focus SE
mountaincarjunkie
alschnertz wrote: 12 Aug 2018, 05:52 The key doesn't actually open the trunk on my '01.
The key fob works with everything else. I'm assuming maybe the trunk switch or latch isn't working? When I use the fob I can hear the mechanism working just nothing happening.
alschnertz
If you can hear the actuator cycling, maybe all that's wrong is a linkage fell off.
And if the actuator is cycling, I'd also think that the problem should be pretty obvious.
Pull the interior panel and have a look. You'll probably have to fold the rear seats and access it that way.
'84 Prelude
'06 MPV
'13 Ford Focus SE
