squeeky steering wheel
davern444
Year and Model: 98 S70
Has thanked: 1 time
Post by davern444 »
The steering wheel in my 98 S70 has a creeky groan inside the car when I turn it sometimes and it sounds like it's coming from right under the wheel near the dash. I recall reading something about it being a bad bushing or something but can't seem to find that post despite searching several times. Anyone have this issue and what bushing are they talking about? It's really annoying and I want to fix it. Any insight or direction is appreciated.
FlyingVolvo
Year and Model: 2000 V70XC
Has thanked: 51 times
Been thanked: 74 times
Post by FlyingVolvo »
Yep, I had that for years. There's a bushing with bearings at the bottom of the steering wheel column inside the car, covered in a plastic plate. The only way to permanently fix it is having the boot and bearing replaced. I had a mechanic do it while replacing my subframe bushings.
Some people have luck shooting some lubricant/grease into the boot, but it's often only a temporary solution as it was for me.
2000 V70XC - 340,000 miles
2023 V60 T8 PE
davern444
Has thanked: 1 time
Post by davern444 »
ecbsykes wrote: 10 Aug 2018, 05:32 Yep, I had that for years. There's a bushing with bearings at the bottom of the steering wheel column inside the car, covered in a plastic plate. The only way to permanently fix it is having the boot and bearing replaced. I had a mechanic do it while replacing my subframe bushings.
Thanks, I'll check it out
Has thanked: 2200 times
Been thanked: 1852 times
Try silicon oil sprayed between the plastic boot and the shaft at the bottom as suggested.
davern444
Has thanked: 1 time
Post by davern444 »
scot850 wrote: 10 Aug 2018, 08:12 Try silicon oil sprayed between the plastic boot and the shaft at the bottom as suggested.
Thanks I'll give it a try
