850 heater fan quit again
swe280Z
- Year and Model: 1994 855 NA mfg 9/93
- Has thanked: 2 times
See my posts from last Feb for backround. Replaced fan relay a few days ago because no high speed o the blower. Finished a/c shim wire tie fix and was testing it out for about 20 minutes only to find out that the fan had quit on all speeds! I'm getting pretty good at getting to and replacing the relay but there most be a more permanent repair. I'm getting more familiar with the knee panels than I want. As you can tell from my earlier posts, I've replaced a lot of the related hardware and done a lot of the electrical troubleshooting. Any suggestions would be appreciated. Thanks in advance.
hausmeister
- Year and Model: 1995 850T5-R
- Has thanked: 276 times
- Been thanked: 85 times
Are you sure the fan is ok? Maybe it is worn out and that causes the issues... You can get replacement motors from bosch.
Not sure which relay you mean. There is a resistor and I think transistor control for the automatic ac (?). If your fan takes too much power to spin maybe that burns them out.
850 T5-R '95 auto
swe280Z
I apologize for the awkwardly-worded rant which I should have checked before submitting. As it turned out, fan speeds 1,2, & 3 started working the next day leaving 4 the only dead one. I ordered 2 (1 spare) relays for the manual control but haven't installed them yet. Any ideas on what could be wiping out the heater fan relay since the blower and resistor are new? If you read my post from the spring of last year, the one terminal was toasted on the relay at that point but worked for months after the relay was replaced. Is that a clue to the problem? The relays are relatively inexpensive but a bit of a pain to replace. Thanks again.
swe280Z
Just finished replacing the heater fan relay again and have all 4 speeds once again. The relay I removed had a bubble on the side (nearest the engine). This is the same terminal that was toasted last year. Still would like a permanent fix. Any ideas? Thanks. Scott
- Has thanked: 1611 times
- Been thanked: 4072 times
Can you post up a pic of the relay and burned terminals?
- BEJinFbk
- Year and Model: '98 V70 R
- Has thanked: 94 times
- Been thanked: 146 times
If the contacts in the connector are bad,
there will be insufficient current flow and
overheating will result.
Have you replaced the connector or are
you just throwing relays at this problem?
swe280Z
Today I tried to remove the burnt female contact from the connector with no luck. The green plastic was crumbling and the contact getting bent. I forced the newest relay back on and got high fan speed again. Then I tried the next oldest relay but still no high fan speed. Now the working relay is securely taped to the connector for the time being. Does anyone have this connector on a parts car that I could splice in? I'd like to get this fixed once and for all. Now that I was able to remove the connector from its mount and see the burned female contact, at least I have a plan! Thanks in advance.
