1990 240 non turbo with high compression readings
akkevint
Year and Model: 245 DL 1980
Post by akkevint »
I recently Purchased a 1990 Volvo purchased a 1990 Volvo 240 sedan. And cylinders 12 and three I had PSI rating of 195 and in the number and cylinders 1,2,3 I had PSI rating of 195 and then the number 4 cylinder I had 200 psi reading.
Any thoughts out there about why these are so high. Maybe cat converter is plugged up?
Any comments welcomed.
AKKevinT
The Reluctant Mechanic
lummert
Year and Model: 760 1988
Been thanked: 26 times
Post by lummert »
From what I read this may be the result of excessive buildup of carbon deposits on the piston top and/or combustion chamber. Normal for B230F is 130 to 160 psi.
1988 Volvo 760 Turbo Wagon
