What ODB2 Scanner would you recommend for ABS related issues
Fosgate
Year and Model: 2011 XC60 R-Design
Post by Fosgate »
Hey guys,
Recently in my 1997 S70 T5 I had the ABS and TRACS light coming on randomly while driving, it then goes off and comes back on as it feels like.
When connecting generic code scanner I get no error codes and also the CEL light is not on either.
So does ABS uses different diagnostic protocol and error reporting mechanism that generic ODB2 readers cannot read?
What reader would you recommend which can read the error codes related to ABS faults?
I do have the VIDA/DICE scanner which I use on our V50 model however as far as I know they do not work with earlier 1997 models..
I suspect the issue is with the ABS module soldering joints (which I know is a common problem for these models) but before I pull the unit out and start re-soldering I was hoping to get the error codes to be sure its not a sensor or something else that causing the lights to come on.
Thanks
RickHaleParker
Been thanked: 980 times
Post by RickHaleParker »
For a pre-99 ... on the cheap
850 OBD-II if you have a Android phone or tablet and a Bluetooth ELM327 dongle.
The older version of VOL-FCR which you can find on the internet and a VAG-COM 409.1 KKL USB interface will do the ABS.
If you are willing to spend $150.00, iCarsoft VOL-II.
Active
Past
Fosgate
Post by Fosgate »
Thanks Rick, so the generic Bluetooth ELM327 dongle will read the ABS codes? I used to have one of these and I gave it away ....
might be good idea to look into iCarsoft VOLII it seems to cover pretty much all Volvos after 1996.
Has thanked: 1611 times
Been thanked: 4071 times
AUTEL 500 series and up will do ABS and SRS on a 1999 and 2005 and presumably everything in between.
Has thanked: 311 times
Been thanked: 817 times
Post by erikv11 »
You can check the resistance on each sensor from up at the module, FWIW.
Matty Moo
Year and Model: 850, 1996
Has thanked: 1 time
Been thanked: 30 times
Post by Matty Moo »
I've never had any luck getting my autel to communicate with the abs on any 96-98 Volvo. The icarsoft does and of course vol-fcr does.
http://www.midwest-abs.com
Simplycleanpowerwash.com
1999 s70 Plain Jane.
2000 s70 GLT
2014 Ram
2012 Jeep Wrangler Unlimited
Clemens
Has thanked: 500 times
Been thanked: 228 times
Post by Clemens »
Have you re-soldered the fault-prone pins? I'd try that first and go from there.
Or send it to matty moo.
1996 855 R,
2010 V70 D5,
misha
Has thanked: 155 times
Been thanked: 432 times
Post by misha »
Vol-fcr only or dealership.
Generic code readers will communicate ONLY with ecu.
You can try VIDA but i'm not sure.
Intermittent abs/tracs are common since EVERY module have cold solders problem.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2861 times
Been thanked: 1332 times
Post by matthew1 »
If you choose to buy your scanner from Amazon, please consider using the MVS link https://www.amazon.com/?tag=matthewsvolvo3-20
It helps. Thanks!
Also -> Amazon link
Chuck W
Year and Model: 97 854 T5
Has thanked: 97 times
Been thanked: 340 times
Post by Chuck W »
I don't have it in front of me, but I picked up an Autel unit a couple of years ago. Worked on my '96 for the ABS and SRS. Should work for a '98.
