Did you know? 🤔
98 s70 overheating
ashvolvo
Year and Model: 1999- S 70 GLT
Has thanked: 0
Been thanked: 0
United States of America
ashvolvo
Re: 98 s70 overheating
Post by ashvolvo » Fri Aug 24, 2018 5:26 pm
Use genuine parts only for the engine coolant temp sensor, do not use after market parts for it. It is called as Temperature sending unit. It is recommended that you change the ECT sensor and Thermostat together. They typically last between 60-80K miles before they start malfunctioning. Here are links from FCP
https://www.fcpeuro.com/products/volvo- ... -9125463oe
https://www.fcpeuro.com/products/volvo- ... s-271664oe
1999 S-70 GLT @168K Miles
1987 740 GLE- Donated @215K Miles
RickHaleParker
Has thanked: 3 times
Been thanked: 562 times
RickHaleParker
Post by RickHaleParker » Fri Aug 24, 2018 6:12 pm
I think Wahler is commonly used without problems, about $12
Wahler is a BorgWarner aftermarket line. BorgWarner claims Wahler is built to the same quality, service life and operational reliability as OEM.
Platform: P80 1998 C70, B5234T3, 16T, AW50-42, Bosch Motronic 4.4, Special Edition package.
Platform: X40 (Nedcar) 2003 S40, B4204T3, 14T twin scroll AW55-50/51SN, Siemens EMS 2000.
Platform P2 2005 XC90 T6 Executive, B6294T, 4T65 AWD, Bosch Motronic 7.0.
Platform P2 2004 S60R, B2524T4, AW50/51 AWD, B8444S TF80 AWD, Bosch Motronic 7.0, BorgWarner K24 turbocharger. V8 conversion in progress.
dj_v70
Year and Model: v70 2003
Has thanked: 5 times
Been thanked: 18 times
dj_v70
Post by dj_v70 » Fri Aug 24, 2018 6:45 pm
I don't believe any of these codes have anything to do with your overheating issue. Googling P0176 says it is for a fuel issue. Someone else will chime in if I am incorrect here.
Based on the information that you have provided so far, it doesn't sound like your issue is the thermostat.
You have noted that it takes something like 10 miles to get up to temperature. That is likely the thermostat stuck partially open. This is a common issue with these cars. A thermostat stuck open keeps your engine cooler, not hotter though, so it is unlikely to be your overheating issue. I bought my 2000 v70 with a thermostat that was stuck open, it took about 10 miles to get up to temperature also, it didn't overheat.
It isn't hard to replace thermostat, I recommend using youtube to get in-depth instructions.
Has thanked: 337 times
Been thanked: 1043 times
Trinidad & Tobago
Post by abscate » Fri Aug 24, 2018 6:46 pm
Wahler, Vernet or OEM Volvo on those parts.
You will need a Torx bit set on the thermostat bolts. Lowe’s has a Kobalt brand which is decent. You want To get the bit firmly in the head socket then give it about 20 light raps with a small hammer. You are shocking the threads to loosen them up for removal. Don’t distort anything, just rattle their world a bit.
Link To Volvo Glossary
ashvolvo
Has thanked: 0
Been thanked: 0
ashvolvo
Post by ashvolvo » Fri Nov 08, 2019 11:31 am
Do not put after market for Temperate sender unit. Put Genuine Volvo
Here it is
here is the thermostat
You will need a T40 to open the 2 screws on top of the thermostat housing unit. sometimes they are a bit*h to take off.
MoVolvos
Year and Model: 03S80T6~08C30T5
Has thanked: 34 times
Been thanked: 70 times
MoVolvos
Post by MoVolvos » Fri Nov 08, 2019 11:48 am
scot850 wrote:
Wed Aug 22, 2018 10:42 am
Thermostat sounds like a good probability as suggested above. Also check that the cooling fan is working.
I agree. Every single description and detail of the problem described by Kprixie happened to my former 98 S70 T5. At first I thought it was a head gasket also but before doing the work I replace the expansion tank and cap but the problem persisted. What I found was the thermostat was missing. The problem could be an opened thermostat so the temperature fluctuated even goong low then overheat (needle in red). I am not sure that it is truly overheating but you have to take the precaution thinking it is.
1998 S70 T5 - Donated
2003 S80 T6
2003 GS300
2003 Odyssey
2008 C30 T5
2019 Atlas SE 4 Motion
misha
Has thanked: 57 times
Been thanked: 145 times
Serbia
misha
Post by misha » Fri Nov 08, 2019 3:55 pm
Kprixie wrote:
Fri Aug 24, 2018 2:09 pm
...Also does anyone know a good brand reliable for the sensor I can order myself online...
Vernet or Wahler.
'91 Citroen XM 2.0 SI /fully equipped/mandarine red metallic
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
misha
Serbia
misha
Post by misha » Fri Nov 08, 2019 4:00 pm
Wahler IS OEM(read OE).
On original thermostat it's stamped Volvo AND Wahler....at least on EU market cars.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
