Last autumn I had a weird ticking sound coming from the car. No other symptoms. Drove well. No codes. Eventually I put my hand behind the engine by chance and felt puffs of warm air.
Turned out one bolt from the manifold had fallen out and one of the gaskets was sitting slightly off. A new bolt later everything was fine.
So if you're hearing the below sound, check the exhaust.
Is your car ticking? Check the exhaust manifold gasket. Topic is solved
Strange ticking sound . No codes. Could be the exhaust manifold.
- Has thanked: 2854 times
- Been thanked: 1332 times
Rattnalle, I promoted your account to MVS Contributor. You've helped Volvo owners so many times, and you haven't even been here one year.
Let me know if you want to keep your avatar as is, if you would like the standard MVS Contributor avatar, or if you would like a mash-up of the two.
- 18838 Views
Last post by skifire
- 6338 Views
Last post by Stilltrying2
- 15504 Views
Last post by Rvolvos
- 19 Replies
- 7952 Views
Last post by misha
- 762 Views
Last post by erikv11
