IPD sale Volvo Parts
Did you know? 🤔
[2001 V70 2.4T] Oil leak, intake side, lower engine / oil pan
2001 - 2007 XC-70
prwood
Year and Model: 2001 V70 2.4T
Has thanked: 4 times
Been thanked: 20 times
United States of America
prwood
Re: [2001 V70 2.4T] Oil leak, intake side, lower engine / oil pan
Post by prwood » Wed Sep 12, 2018 9:42 am
This is the best view I could get without taking anything apart. Using my iPhone in video mode with LED illumination, holding my hand in the vicinity of the intercooler-to-throttle tube and starter. You can sort of partially see the metallic sleeve around the lower hose from the breather box to the block, but the starter is blocking most of that view.
It seems like everything is oily, so I'm not sure if this is helpful in pinpointing anything.
View from side
Cars I've owned:
- 2015 to current: 2001 Volvo V70 2.4T
Has thanked: 187 times
Been thanked: 594 times
Trinidad & Tobago
Post by abscate » Wed Sep 12, 2018 2:09 pm
Really oily up top but not enough for flow.
Crack in th ebottom of the box, maybe?
dj_v70
Year and Model: v70 2003
Has thanked: 2 times
Been thanked: 16 times
dj_v70
Post by dj_v70 » Wed Sep 12, 2018 4:24 pm
Inconclusive. Recommend using engine cleaner to clean and then try again. You can get a $20 usb borescope and get a better look at all angles.
Trinidad & Tobago
Post by abscate » Thu Sep 13, 2018 5:38 am
Really wet on that knock sensor....
prwood
prwood
Post by prwood » Thu Sep 13, 2018 6:12 am
I just ordered a borescope, so I should be able to take a look this weekend without tearing things apart.
Cars I've owned:
chrism
Year and Model: S80 / 2005
Has thanked: 0
Been thanked: 17 times
chrism
Post by chrism » Thu Sep 13, 2018 2:01 pm
Did you order the type that connects to your cell phone? I'd be interested in knowing how well those work.
prwood
prwood
Post by prwood » Thu Sep 13, 2018 2:18 pm
I did. From what I gather, the hardware on these is okay, but the viewer apps are junk, but if you set everything up in the right order it's supposed to work ok.
Cars I've owned:
prwood
prwood
Post by prwood » Sat Sep 15, 2018 9:08 pm
Okay. The endoscope wasn’t super helpful. I tried getting photos with both my phone and the endoscope after cleaning things up under the intake manifold. Frankly, the endoscope pictures aren’t worth posting. Anyway, here’s a phone photo from before the cleanup and then one from after cleanup and driving around for a while.
Before cleanup
After cleanup and driving.
It looks to me like the leak is coming from the top connection between the engine block and the breather box. You can see what looks like fresh oil underneath the hose.
Cars I've owned:
Rattnalle
Has thanked: 15 times
Been thanked: 100 times
Sweden
Rattnalle
Post by Rattnalle » Sun Sep 16, 2018 2:48 am
It looks to me like that hose clamp light be sitting too far out from the engine to seal the connection properly.
Trinidad & Tobago
Post by abscate » Sun Sep 16, 2018 3:51 am
Definitely a leak there ( maybe clamp has cut hose?) but there is oilabove that too, maybe more than one leak?
