HELP! 2007 Volvo S60 2.5T into 2004 Volvo S60 2.4 Interior Swap Help! Request
hersch
Year and Model: 2004 Volvo S60 2.4
Post by hersch »
All,
I have a 2004 Volvo S60 2.4 with cloth manual seats. I found a full set of leather electronic seats out of a 2007 Volvo S60 2.5T and was wanting to put them into my car. Before I do this I wanted to find out if this is possible. I know the bolts will matchup for the seat rails. My concerns come in with adding electric seat to one that does not have them and if the wiring does not matchup, can I just put a seat module from the 01-04 seats? Below is a full list of what I want to put into my 04 from the 07, can someone please tell me if each part will work or not and if modification is required, what is required. Thank you in advance! -- Hersch
Interior Door Panels
Full Leather electric seat set (heated seats, so I assume that I need the buttons on the dash and wiring?)
Center console (Cup holder and jockey box)
E-Brake handle with boot
Trim around gear shifter (Taking out of automatic and putting into manual, 5-Speed)
Trim around radio
Trim on dash Jockey box
darylrobert
Year and Model: V70 240 740t xc70
Has thanked: 6 times
Been thanked: 44 times
Post by darylrobert »
It can be done all the wiring should be there but you have to get the module programmed by Volvo i hear or just use DPDT relays and rewire the factory switches direct to the relays. i used 8 relays in total 2 for each motor so they have to be micro relays more than 2amp
micro relay.jpg (9.05 KiB) Viewed 1821 times
