1980 264 GLE - Bad ECM?
The brother to a colleague of mine has a 1980 Volvo 264 GLE which suddenly shut down and is now at the local "foreign car" mechanic in our small town. He says it has a bad ECM but seems a bit reluctant to get involved. He asked me for advice and now I asking you all: Any experience with this car or problem? I assume ECM stands for Electronic Control Module but I have never had problem with this on my Volvos (1990 240 and 1996 850). I have not been able to find any on the web so far - most information and parts are for the 2.3 I-4, not the V-6. Can anybody help? Thanks
jimmy57
- Has thanked: 5 times
- Been thanked: 322 times
There is an ignition module responsible for using a pulsed signal from the ignition pickup coil in distributor. That could make it not have spark. They are pretty reliable. The pickup coil in distributor is more likely to break a wire from timing advance movement in my experience.
There are modules for the lambda sond fuel mixture control and for idle speed regulation. These last two usually do not result in engine failing to start.
lummert
- Year and Model: 760 1988
- Been thanked: 26 times
3501752 (0 280 001 510)(0 986 261 828) Bosch LMM No. 0 280 213 006
Fits: B280F 11/1986 -> 07/1988
3517846 (0 280 001 512)(0 986 261 829) Bosch LMM No. 0 280 213 006
Fits: B280F 08/1988 ->
5003797 replaces both 3517846 and 3501752
0 280 001 512 fits 760 2.8 8/88-8/91, 780 2.8 4/87-7/91, 960 2.8 9/90-8/91
1274698 (0 280 001 504)(0 968 261 828) Bosch LMM No. 0 280 213 006
Fits B280F -> 10/86
0 280 001 504 replaced by 0 280 001 510
These are all B280F with LH 2.2
Seems this car would have K-jet.
K-jet idle speed control unit 1274711; 1274452 (Bosch 0 280 220 008)
240 2.7L 1980
240 2.8L 81-84
260 2.7L 79-80
260 2.8L 80-84
760 2.8L 83-86
Fits B280F -> 10/86
240 2.7L 1980
240 2.8L 81-84
260 2.7L 79-80
260 2.8L 80-84
760 2.8L 83-86
1988 Volvo 760 Turbo Wagon
- 93Regina
- Year and Model: 93:240/940
- Been thanked: 65 times
All relevant info can be found here: Volvo 240 & 260 service manual
Here's a good starting place: Volvo 240 & 260 ignition system service & repair manual (all models)
Jimmy57 said, "The pickup coil in distributor is more likely to break a wire from timing advance movement in my experience."
If your mechanic is not old enough, he may not understand. Pickup coil is located on a rotating plate, and its wire, attached to it and distributor's peripheral core, over time will break its copper wires internally. Since there is a rubber type coating, this will not be seen. This may not be the issue, but mechanics have fumbled the ball when diagnosing a defective wire.
- 698 Views
Last post by mechanic
- 597 Views
Last post by Tgmitchell
- 688 Views
Last post by volvolugnut
- 3833 Views
Last post by PixelDust
- 5226 Views
