2008 c70, driveshaft
Rbaratt
Year and Model: 850,S70,C70
Post by Rbaratt »
Need a good vendor for rebuilt driveshafts. Any suggestions, Raxles No longer rebuilds Volvo shafts.
2008, C70, 44,000 miles
2000, S70, GLT, 67,000 miles
1995, 850, GLT, 144,000 Miles
1996, 850, Turbo, 226,000 Miles (TMU)
RickHaleParker
Been thanked: 978 times
Post by RickHaleParker »
A1 CARDONE® Remanufactured Products is still doing remanufactured axles. You can buy them on eBay and through a lot of other vendors.
"CARDONE Technology ensures that all CV axles meet or exceed O.E. form, fit and function. 100% Neoprene boots are designed with additional bellows to resist bellow stress and ozone cracking, the leading cause of boot failure. Boot clamps are pneumatically crimped creating a perfect seal between the boot and housing. High quality grease withstands high-temperature and high-torque demands to ensure long-lasting, reliable performance. A new axle nut is supplied with every unit for hassle-free installation, as the old nut on the vehicle is typically worn or stripped. Splines are precision rolled to ensure proper fit of axle into the mating hub and transmission, which eliminates installation hassles. Threads are precision rolled to ensure proper fit when axle nut is installed. Transmission seal diameter is precision-machined after heat treatment to ensure correct surface finish, promoting long seal life. Axle is measured 100% after assembly to ensure proper fit.'
Active
Past
