240 1993 specific horn
leucadiacruiser
- Year and Model: 1993 240 wagon
- Has thanked: 2 times
Hi all - Do I understand that the 1993 240 has a specific one piece horn, versus other years that have a low tone/ high tone two part horn? If that is correct - can anyone direct me to a plug and play replacement? I know it is just the horn versus button or relay. Just looking for an easy replacement. Everything I've looked at online eBay/europarts/etc. Sells just low tone/high tone. Thanks in advance.
1993 240 Wagon
It would be unusual for a car maker to use a one year only horn with a large model line.
Volvo parts lisle shows the 1993 with two tone horns, so the single horn info is debatable.
Part number is 3540907 but NLA, junkyard Is best bet.
leucadiacruiser
Thanks @abscate - wrecker yard it is. It does only have one connection for a horn which is why I was thinking the info I read (somehwere) about one horn could be accurate.
1993 240 Wagon
leucadiacruiser
If anyone can snap a picture of their '93 behind the grille that would be even better!
1993 240 Wagon
leucadiacruiser
Indeed looks like a single unit. From my local dealership parts department:
"Your model year requires one 400Hz horn #3540907. Earlier years had two, a high (420Hz) and a low (335Hz). All have been discontinued, in case you were entertaining the idea of switching one for two.
If you're going to try e-bay:
1235449 = 335Hz
1235450 = 420Hz"
1235449 = 335Hz
1235450 = 420Hz"
1993 240 Wagon
- 4087 Views
Last post by MazdaDude
- 760 Views
Last post by 95850glt
- 1709 Views
Last post by precopster
- 833 Views
Last post by Lindsv70xc
- 1882 Views
