IPD sale Volvo Parts
Did you know? 🤔
S40 Engine B4204T3 Blue smoke when idle
1996 - 2004 S40
1996 - 2004 V40
jumbicat
Year and Model: 2003 S40 2004 S60
Has thanked: 0
Been thanked: 0
United States of America
jumbicat
Re: S40 Engine B4204T3 Blue smoke when idle
Post by jumbicat » Mon Sep 03, 2018 5:29 pm
Just bought a new tester.
Dry readings:
165-165-163-165
jumbicat
Has thanked: 0
Been thanked: 0
jumbicat
Post by jumbicat » Mon Sep 03, 2018 6:11 pm
Inrercooler hose was dry. no oil./ Just checked the big hose only. If I need to check others, let me know.
I did a wet test and used hardly any oil and same result.
Schrader valve had to be taken out and cleaned to get regular readings again. Advised the clerk where I borrowed the tester that they might check it due to operator error. he appreciated the pass down and commented on stories of returned tools completely destroyed.
Put the plugs back in and it started up without hesitation and ran fine...
alschnertz
Year and Model: 1995 854T
Has thanked: 1 time
Been thanked: 7 times
alschnertz
Post by alschnertz » Mon Sep 03, 2018 6:37 pm
And no smoke?
'84 Prelude
'06 MPV
'13 Ford Focus SE
jumbicat
Has thanked: 0
Been thanked: 0
jumbicat
Post by jumbicat » Mon Sep 03, 2018 7:00 pm
lots of smoke. Should I take a video?
alschnertz
Has thanked: 1 time
alschnertz
Post by alschnertz » Mon Sep 03, 2018 7:04 pm
Lots of smoke at this point wouldn't surprise me since you've dumped a bit of oil down the cylinders.
Still have to do some thinking on this.
Good thing you have another car to use.
'84 Prelude
'06 MPV
'13 Ford Focus SE
jumbicat
Has thanked: 0
Been thanked: 0
jumbicat
Post by jumbicat » Mon Sep 03, 2018 7:24 pm
Thanks again for the feedback.
It's greatly appreciated.
RickHaleParker
Has thanked: 3 times
Been thanked: 305 times
RickHaleParker
Post by RickHaleParker » Mon Sep 03, 2018 9:23 pm
Pull the intercooler hose look inside the hose and turbo. You may of blew the seals in the Turbo. If you find oil in the intercooler hose or turbo you will know the problem is in the intake system not the engine ... process of elimination.
Platform: P80 1998 C70, B5234T3, AW50-42, Bosch Motronic 4.4, Special Edition package, Plant: Uddevalla Sweden.
Platform: X40 (Nedcar) 2003 S40, B4204T3, AW55-50/51SN, Siemens EMS 2000. Plant: Born Netherlands.
Platform P2 2005 XC90 T6 Executive, B6294T, 4T65 AWD, Bosch Motronic 7.0, Plant Torslanda Sweden.
jumbicat
Has thanked: 0
Been thanked: 0
jumbicat
Post by jumbicat » Mon Sep 03, 2018 9:28 pm
I don't think this has a turbo on it. Maybe it does. I'll check
RickHaleParker
RickHaleParker
Post by RickHaleParker » Mon Sep 03, 2018 10:17 pm
All the AME S40 NedCars (2000 - 2004) are turbocharged. The "T" in B4204T3 is for Turbo.
Start at the air filter and follow the air hose to the Turbo on the back side of the engine. The intercooler hoses/pipes run from the Turbo to the radiator then to the engine. The hose/pipe from the Turbo to the radiator is the one you want to check.
difflock54
Year and Model: V40 Nordic 2002
Has thanked: 6 times
New Zealand
difflock54
Post by difflock54 » Tue Sep 04, 2018 2:04 am
Yes, I agree with this comment.
If the transmission slipped out of gear suddenly under the excess load on the on ramp the engine will likely have red lined and that will cause the turbo boost to go to maximum or more instantly. The oil seals have quite likely blown.
The B4204T3 engines have a 12T turbo normally. You can see it just below the alum' foiled exhaust manifold heat shield between the firewall and the rear of the engine.
