Radiator Cooling Fan Won't Turn Off (2010 Volvo XC60 T6)
Help, Advice, Owners' Discussion and DIY Tutorials for the groundbreaking new Volvo S60 2011+, V60 2015+ XC60 2010-2018.
Dzikiewicz
Year and Model: 2011 xc60
Re: Radiator Cooling Fan Won't Turn Off (2010 Volvo XC60 T6)
Post by Dzikiewicz »
Hi everyone
I just got this problem as well, problem is I’m from Canada and I’m in New England. Can I just unplug the smaller fan and expect the larger fan to take care of some of the load? Or if I unplug the smaller fan from the module will both fans not work? What warning can I expect of the car starts to overheat?
ClarkKent
Year and Model: 2010 Volvo XC60
Post by ClarkKent »
Howdy! I've been around the block many times with this. It's very frustrating and I feel your pain. I'm no expert but, I was able to resolve this buy purchasing a new control unit. (Volvo no longer sells the control unit individually and requires you to buy the whole fan).
I purchased my initial ECM on Ebay - it's very low risk because it was $30. I found one that offered a decent warranty. It worked ok but, after 2 months had some issues. Requested refund and purchased a second off Amazon. I had some minor issues BUT, I think it was a result of the connectors. I played around with them, tested and knock on wood the car is working fine. If you don't want to go that route, you can purchase a Gates brand online or at a parts store for around $125+. It's a simple install - 1 screw and attach the connectors.
Hopefully this helps! Let us know what route you selected and GOOD LUCK!
UPDATE - FOLLOW THIS POST FOR EXACT INSTRUCTIONS and please read Jimmy's comments - HE'S THE BEST!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
viewtopic.php?f=26&t=91254
RickHaleParker
Been thanked: 690 times
Post by RickHaleParker »
Dzikiewicz wrote: Tue Oct 15, 2019 11:30 am Can I just unplug the smaller fan and expect the larger fan to take care of some of the load? Or if I unplug the smaller fan from the module will both fans not work? What warning can I expect of the car starts to overheat?
You can disconnect the smaller fan and drive back to Canada. At speeds over 30 MPH one does not need a fan. The natural air flow from the movement of the car will do the trick. If you get in stop and go traffic it might start to overheat. Don't let the engine idle for very long when you are not moving.
Your biggest challenge would be the stop and go at the border. You might consider crossing late at night when there is very little traffic.
You might want to stop right before the border and let the engine get cold.
Dzikiewicz
So I’ve actually driven for about 600 km in New England. I’m lucky because I brought a OBD thing that gives me a live read out of the temp sensor. It’s been around 90 c the whole time. What temperature does the warning light come on? And I suppose the big fan won’t come on?
Dzikiewicz
Also, if I plug in the small fan will that prevent my car from overheating
maverick455
Year and Model: 2010 XC70
Post by maverick455 »
I purchased a Cooling Fan Control Module off of eBay for around $32. It lasted one year before it failed. I'm trying a Gates unit now from Rock Auto for $110.
Year and Model: Lots
Been thanked: 113 times
Post by precopster »
You can separately power the fans with a 12V source to test them while disconnected from the fan module. The presence or otherwise of small sparks is hardly a conclusive diagnosis as the issue may be that a foreign object is lodged behind the fan preventing it from turning.
The whole assembly is relatively easy to remove and test.
Current cars:2002 XC70, 2006 Ssangyong Rodius (Stavic), 2006 XC90 2.5T, VW Transporter 2.5TDI
www.precisioncarmodules.com.
Dzikiewicz
Update: I drove into Montreal a few days ago, the car hit 94c so I pulled over and plugged in the module and was fine driving through the city. Since then I’ve driven home to west Toronto with the fan unplugged, upon my arrival the new eBay module was waiting on my door step and has been install. For people who have the problem in the future. Just know the fans turn on at 98/ 99 C. Also I would not recommend driving over 30 mph with the fan plugged in because I imagine the fan motor would now be fighting with the air flowing through the radiator, although I’m not positive of this stress, it just makes sense to me.
