Secondary air
Hateprojects
- Year and Model: 98 volvo v70
- Has thanked: 6 times
My secondary air pump is not switching on when the diverter valve opens. The pump is good. I have ran it by pushing the contact points closed at the relay.
- RickHaleParker
- Been thanked: 979 times
Did you check the coil on the relay? The relay won't switch if the coil is open.
Active
Past
Past
Hateprojects
I will start with that. It's setting next to the exact same relay, I'll swap them.
Hateprojects
Ok swapped relay, relay is not thethe problem.
- 31 Replies
- 5656 Views
Last post by MrAl
- 539 Views
Last post by jasonhillpdx
- 860 Views
Last post by alschnertz
- 23 Replies
- 3720 Views
- 777 Views
Last post by RickHaleParker
