1989 240 GL with 310k miles
My wife has complained about our wagon "loading up" and I have never experienced it until this morning. I have been driving the car every day for the past 6 months trying to see what she was talking about with no signs of issues. Today it started fine and after warming up for about 5 minutes it began to chug like it was not getting fuel or air or mixture was off. Last night it was parked nose down at an angle (a first in the 6 months) and it took longer to warm up due to a cooler morning. She mentioned that this issue seems to happen when letting it sit stationary and warm up too long. After a few good revs it seemed to "clear itself" and I drove it to work without any more hang ups. I have done the flame trap/pcv, plugs/wires, vacuum hoses and MAF in the past year. Any help on some self diagnosis would be beyond amazing.
Thank you!
Choking...loading...?
ChadLee
- Year and Model: 1998 V70
- Has thanked: 6 times
1986 245 DL, 1989 244, 745 Turbo and 1981 245 DL - gone to new homes
1989 245 GL - Wife's daily driver
1989 245 DL - In the works for a daily
1998 V70 - Daily driver
2001 V70 - Next project
jimmy57
- Has thanked: 5 times
- Been thanked: 322 times
On 240s of that year range an exhaust leak at manifold to head or at front exhaust pipe to manifold can let air be sucked in between exhaust pulses. The signal will go lean on oxygen sensor as a result and it will richen mixture. At faster engine speeds the pressure pulses are less likely to draw in the air.
ChadLee
Is there a way to test or remedy this in my driveway?
- 93Regina
- Year and Model: 93:240/940
- Been thanked: 65 times
At what point in time does Closed Loop happen?jimmy57 wrote: 04 Sep 2018, 11:38...exhaust leak at manifold to head or at front exhaust pipe to manifold can let air be sucked in between exhaust pulses. The signal will go lean on oxygen sensor...
ChadLee
If my ears hear something, what might that be and how will they remedy the situation?
- 24 Replies
- 11837 Views
Last post by precopster
- 11 Replies
- 1971 Views
- 690 Views
Last post by shiloh51933
