Hello.)
I have some issues with my 2006. V50 1.6 (D4164T). While driving, suddenly after ca 30/40 minutes I loose power (turbo pressure). And then its unstable come and go. The car Aint stopping, just protecting itself or something?. I have changed the dpf without any luck, the vacum hosses to dpf is ok. I also checked the hoose to the turbo controller. Its OK. And offcource the other Hooses related to the tubo/airfilter intake and so on. I have done the big and expencive 125000 service intervall including the DPF and offcource Dieselfilter.
Do you gies have any ideas?. I have read something about EGR and the turbo controller?
KM on my car 135.000.
Fault codes from vida:
1. ECM - 1517 Turbo control - Pressure too high
2. ECM – 9130 Inlet control valve – qualifier unknown
3. Ecm – 9140 Inlet control valve - Jammed
Best regard
"Rogermore1986"
Loosing power after aboutet 30/45 minutes (Turbo pressure)
- 1388 Views
Last post by Orchid70
- 1371 Views
Last post by MadeInJapan
- 1119 Views
Last post by m-k-white850
- 973 Views
- 920 Views
Last post by Bero
