Which auxiliary power relay to replace? Topic is solved
Original owner of 1998 S70 with 332k miles. Car starts, headlights are on, fuses good, but radio, windows, heater fan, wipers all won’t go on. Which relay am I looking to replace? Or is it a worn out ignition key switch? Thanks for your ideas!
- misha
- Has thanked: 155 times
- Been thanked: 432 times
All of them in the same time to go bad....i would say...ignition switch.
I guess that you allready checked the fuses.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- BEJinFbk
- Year and Model: '98 V70 R
- Has thanked: 94 times
- Been thanked: 146 times
If you suspect an aux relay, I believe that 2/30 is the one you want.
It’s called out as 105 on the attached chart. It can be swapped with
the adjacent 106 relay to confirm your theory.
- misha
charleyc wrote: 10 Sep 2018, 14:13 Thanks for advice all. Turns out the ignition key switch assembly is starting to fail. You can wiggle or turn the key a bit and aux power is restored to all. I can live with it for a while....
misha wrote: 05 Sep 2018, 13:46 All of them in the same time to go bad....i would say...ignition switch.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
