IPD sale Volvo Parts
Shorted turn indicator wire, fixed but still not working
Help, Advice, Owners' Discussion and DIY Tutorials on the current (third) generation Volvo V70 wagon and XC70 crossover, and second generation S80.
This is a forum for owners or prospective owners of the third generation V70, second generation S80, and its siblings built on the EUCD platform.
SGV70
Year and Model: v70 2008
Singapore
Post by SGV70 » Fri Sep 07, 2018 2:05 am
2008 v70, indicator wires in RH headlight assembly shorted.
Fixed the wires but no right side indicators front and back, mirror one is working.
Emergency lights only operate left side and right mirror.
No warnings on dash
Fuse is common to both sides, where do I look next?
SuperHerman
Been thanked: 60 times
United States of America
Re: Shorted turn indicator wire, fixed but still not working
Post by SuperHerman » Sat Sep 15, 2018 11:59 am
I assume you checked the fuse. Did you check wires for short and/or power? If those pass look at the bulbs.
jimmy57
Been thanked: 68 times
Post by jimmy57 » Sat Sep 15, 2018 12:16 pm
Transistorized power supply with overcurrent protection. Disconnect batt negative cable and then hold it to the pos cable to drain capacitors to assure module memory is dumped. Hold for 10 seconds. Then reconnect and see if it functional again. 2005 and later can have this happen on many circuits in lighting. It showed up concurrent with 13V power supply limiting to bulbs for longer bulb life.
Who is online
Users browsing this forum: No registered users and 2 guests
