I've noticed that the speed of the cabin air fan varies intermittently on my 2009 S80, for no apparent reason (regardless of whether I'm accelerating, at idle, at a constant cruising speed, whether or not I'm recirculating air or taking in air from outside, whether using the A/C or heat). I've taken it in to the dealer (I have an extended warranty), and they found no trouble codes, so they didn't do anything. I replaced the cabin air filter, which did not help.
Anyone else experienced this? Also, I have a month left on my extended warranty. Do I have any basis for pushing the dealer to replace whatever part might be causing this, even without a trouble code?
Cabin Air Fan Speed Varies
- Year and Model: 2009 S80
- Year and Model: 1999 V70T5, 2005 V70
- Has thanked: 130 times
- Been thanked: 402 times
Re: Cabin Air Fan Speed Varies
It will vary according to heat load, solar load, speed of car - to maintain the cabin at the setpoint.
Does it vary if you set the fan button in the middle of the range?
1 SWMBO for 30 years
2 Volvos
3 VWs
4 Careers
5 cats/dogs/gears
6 Perfect Ladies in waiting
7 Drivers
8 Boats- with a big pointy metal thing on top
1999 V70 T5M 56 2005 V70 NA M56 VWs BMW
2 Volvos
3 VWs
4 Careers
5 cats/dogs/gears
7 Drivers
- oragex
- Year and Model: S60 2003
- Has thanked: 74 times
- Been thanked: 123 times
Does it also vary in manual mode? P3 models have issues with the blower regulator www.youtube.com/watch?v=z-9SKu49LBE
2003 2.4i S60 automatic 125k miles
DIY Volvo repairs videos https://www.youtube.com/playlist?list=P ... s0FSVSOT_c
This is in manual mode, I don't usually use auto. It doesn't seem to matter regarding any variables. It will be normal speed, blow hard for a second (maybe half a second even), then go back to its set speed, maybe slow down for a second, then back to set speed, etc. This happens at all set speeds.
- Been thanked: 100 times
No noise? That is something I have seen with the blowers on those cars before they go out. Usually they make a high pitched squeal. I don't always hear the squeal but females do. Ladies have better hearing range than men.
Yeah, no noise. My wife can't hear anything abnormal (other than the varying fan speed). I guess I'd like to know if anyone knows what might be the cause, but also, if I have any justification for demanding a new blower without any trouble codes. I guess it's hard to say exactly what to replace though without any trouble codes.
- mrbrian200
- Been thanked: 64 times
Who would know this (I'm not sure)...
Is the output from the regulator to the fan motor high frequency PWM or true DC (variable)?
How to proceed would depend on this difference and whether you have access to either a voltmeter or oscilloscope depending. Voltmeter for DC, scope for PWM.
- oragex
Also blow some air here or put the vacuum on it, it's the cabin temp sensor and may get covered with dust & stuff - don't touch it physically
- 1.jpg (36.26 KiB) Viewed 317 times
- oragex
I would think blower regulator. Push the dealer for warranty before it's too late. It's a $1200 job. It won't give codes, but it's a very well known issue. Soon it will die and you will have no choice to replace it. Maybe try another dealer if not too far away.
Who is online
Users browsing this forum: No registered users and 3 guests
