The 850 wagon hatch (tailgate) U shaped upper fascia piece has 5 clips along the top (the center one being different)
However, the sides have a square projection which seems to be the receptical for some kind of clip. Looking at the car body, there is a 3-4" long piece of 1/4" thick foam tape in that area. They look somewhat torn. What sort of clip goes along the sides? Or is it just a friction fit on the thick foam tape?
(the center one being different : Drg item #25
25 Clip
black 9132876 $2.99 $2.80
https://www.volvopartswebstore.com/show ... egory=7854).
http://volvopartslisle.com/assembly/245 ... s-Tailgate
"PANEL" TAILGATE UPPER FASCIA CLIP ON SIDES NEED 4 ACROSS THE TOP and there is some kind of receptical on each side
2 Item(s) In Cart
Drg #24
Clip
PART NUMBER: 6818403
RECOMMENDED QTY: 2
• gray
• FOR 9132880
$1.61 SAVE $0.41
TAILGATE UPPER FASCIA CLIP, CENTER NEED 1
Drg #25
not avail at this vendor.
REPAIR KIT for lower fascia panel, both the plastic & carpeted portion
Drg# 26
1 Item(s) In Cart
Repair Kit
PART NUMBER: 9451866
RECOMMENDED QTY: 1
$11.01 SAVE $2.76
SEE VIDEO HERE
https://www.ipdusa.com/products/4807/12 ... repair-kit
"PANEL,GREY" TAILGATE LOWER FASCIA CLIP NEED 4
Drg #4
Clip
PART NUMBER: 9145885
RECOMMENDED QTY: 4
$2.40 SAVE $0.63
850 Wagon Hatch tailgate UPPER trim fascia - side clips?
- 450 Views
Last post by volvolugnut
- 680 Views
Last post by paredown
- 790 Views
- 2332 Views
Last post by readallthebooks
- 2631 Views
