Hi All:
Just discovered that my driver's side control arm is shot-- lots of play in the ball joint (as well as the tie rod end). I see that Rock Auto has MOOG control arms for $58 Canadian dollars. MOOG used to be a good brand-- has anyone used these?
Any other recommendations? At 290K km I don't think it is blue box-worthy...
2000 V70: anybody use MOOG control arms?
Herb Goltz
- Year and Model: 04& 06 XC70, '12 s60
- Has thanked: 7 times
- Been thanked: 5 times
2012 s60 t5
2006 XC70
2004 XC70
2006 XC70
2004 XC70
BlackBrick
- Year and Model: 1997 850R
- Been thanked: 3 times
Don't know about 2000's, but both my 850s I've tried different control arms. Volvo OEM lasts a good 10 years. Anything else I've tried lasted 2 years. Up to you.
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
I've read mostly good things about Moog, but also one bad review. They also can change their sources. But at $58 I would be surprised to be a good quality. Decent quality starts at $120USD/side for an IPD HD so you see why I say that for a $58CAD arm. But again, if the car will only drive for another year or two maybe Moog will do.
- misha
- Has thanked: 155 times
- Been thanked: 432 times
Moog is Federal Mogul brand....pretty reputable brand in EU.
Oem quality for fair price.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- Been thanked: 4064 times
Onmy 1999, same control arms I believe
FEBI $66
Lemforder $96
Blue Box $166 (probably Lemforder)
I went with Lemforder as the price difference was less than the 2 hours at $25 I pay myself to redo the job
FEBI $66
Lemforder $96
- nickelghandi
- Year and Model: 1998 Volvo S70 GLT
- Has thanked: 14 times
I haven't used them on my Volvo yet, but I have a Nissan Pathfinder and Ford F150 that both used Moog control arms and tie rod ends. The Pathfinder has had them going on 5 years now without issue. The F150 less than a year, but still no issue. The Pathfinder also has Moog rear springs. They seem to be a good brand. The parts haven't rusted at all and the rubber bushings all still look good.
My 98 S70 has some URO Parts lower control arms on the front that need to go. Maybe outer tie rods too. I will likely use OEM, but wouldn't hesitate to use Moog if it came to it. I believe they have a lifetime warranty too so if they do fail, you can just replace them. The job isn't that bad on these cars.
-Nick
clifford06
- Year and Model: 2000 T5
- Has thanked: 6 times
- Been thanked: 4 times
I use Moog on my Dodge Ram 1500. So far good. Just be sure to do booth sides. Three year warranty if I am correct.
shaker_chi
- Year and Model: 94 850, 98 S70T5 M
- Has thanked: 3 times
I will echo others on her about Moog. I have Moog control arms on m 2007 Ford Escape and have done quite well. I have a cousin who works for Ford and he told me when you purchase Moog, they typically have a O/E equivalent part and a cheaper part. So when I bought my control arms for the Escape, Moog had a $69 control arm and a $99 control arm. Obviously, the more expensive one was the O/E equivalent. Do a bit of research and you should be fine. Lastly, since there probably isn't a huge market for Volvo control arms, they may not make 2 versions.
BlackBrick
I've use Lemforder instead of blue box a few times for other parts with good success. Just make SURE the Moog does not say 'made in China'
- mrbrian200
- Been thanked: 84 times
The makes/models mentioned above where people have had good luck with Moog use the same basic style/configuration LCA+bushes as the P80. Except the Ford Escape which is more like the P2s but with a different geometry that would be less stressful on the rear bush.
It'll probably be fine. If your V70 was one year newer (P2) their LCA would probably be a no go.
- 16 Replies
- 2694 Views
Last post by 98v70dad
- 26 Replies
- 7019 Views
- 1904 Views
Last post by sleddriver
- 2640 Views
Last post by MoVolvos
- 697 Views
Last post by br0dy519
