Hello,
A couple of days ago , I changed all of my rear tail lights except the turn signal one over to Led's. But now I get a message on my dash that says check stop lights and bulb failure position light. Could this be because of the LED'S? They all work and I checked my high position light to see if any bulbs are burnt out but none are in that. So all lights are working and look great! But I get that message. Also could I have my service shop go in and turn that off with a tech 2?
2009 xc90 Changing rear tail lights to LED
- GenericVolvoDriver
- Year and Model: '13 XC90 & '12 XC60
Yes, the XC90 REM is monitoring the current consumption of the bulbs - the LED's use much less current, so set of the bulb out error. There's a board level modification you can make on the REM, or you can install "error fix resistors" to draw enough current and turn off the message. The error fix resistors even come as clamp on modules, and are the easy fix.
2013 Volvo XC90 AWD Platinum (Climate package, walnut inlays + wheel, BLIS, active bi-xenon headlights) 131k km
2012 Volvo XC60 T6 AWD Platinum (Technology package, climate package) 17k km
2003 Acura TL Type S A-Spec (2007 Accord V6 trans swap, Tein SS, all available engine bolt ons, Apexi AFC, etc.) 108k km
1988 Nissan 300ZX Turbo (2+2, T-top, Aztec Red, collector plates) 80k km
- ggleavitt
- Year and Model: 06,08 XC90 V8
- Has thanked: 26 times
- Been thanked: 134 times
http://volvo.budzynscy.com/myvolvo/inde ... -for-cars/
https://forums.swedespeed.com/showthrea ... ht-Upgrade
https://www.volvoforums.org.uk/showthread.php?t=267220
viewtopic.php?t=78724
Nice info, thanks for reply!GenericVolvoDriver wrote: 14 Sep 2018, 01:32 Yes, the XC90 REM is monitoring the current consumption of the bulbs - the LED's use much less current, so set of the bulb out error. There's a board level modification you can make on the REM, or you can install "error fix resistors" to draw enough current and turn off the message. The error fix resistors even come as clamp on modules, and are the easy fix.
2012 Volvo XC60, 3,300 lbs , 30.8 ft³, 67.4 ft³ with seat area, Up to 19 city / 25 highway
Cheers, Diceus
Cheers, Diceus
- 11 Replies
- 15819 Views
Last post by DavidArman174
- 3460 Views
Last post by BEJinFbk
- 783 Views
Last post by Cookeh
- 3272 Views
Last post by ogatrulle
- 1203 Views
Last post by Legofan
