I just purchased a 1994 940 recently and I was hoping to figure out what the A6 error code 144 means and what I need to do to repair it or solve the problem. The car has no issues with ignition so far and I thought that error code was related to the ignition.
Thank you in advance!
Error code 144 in A6 diagnostic section
falconstar16
- Year and Model: 1994 940
- Has thanked: 1 time
- RickHaleParker
- Been thanked: 977 times
A6 = Ignition
1-4-4 = Load signal
Diagnostic trouble code (DTC) information
Condition
The load signal in the part load range is tested twice every engine revolution.
If the load signal is constantly high or low diagnostic trouble code (DTC) 1-4-4 is stored
Possible sources
Engine lacks power, stalls, does not start or runs jerkily.
1-4-4 = Load signal
Condition
Possible sources
- Open-circuit or short-circuit to ground in the cable between LH 2.4 #25 and EZ 116 K #8.
LH 2.4 control module defective.
Open-circuit in power supply to fuel injection system control module.
Active
Past
Past
falconstar16
Hi
thank you for the reply
Where are these possible sources of fault are located? (if there is a diagram or something that would be helpful)
Also, can I easily fix these issues and what do I need to do to check or fix the sources?
Thank you!
Thank you!
Taylorlharris90
- Year and Model: 1991 240
Any new insight on this issue? I’m chasing the same code down myself, however, with different symptoms. Once the car goes into close loop the idle is very high, like 1300 rpm. It always starts right up has never stalled out or died on me and the code seems to be intermittent. Any help is greatly appreciated
- 949 Views
Last post by Taylorlharris90
- 2389 Views
Last post by RickHaleParker
- 5185 Views
Last post by plarose
- 615 Views
Last post by MrAl
- 14 Replies
- 2145 Views
