IPD sale Volvo Parts
a/c leak. Use or don't use stop-leak product?
Year and Model: 1999 V70T5, 2005 V70
Has thanked: 129 times
Been thanked: 399 times
Trinidad & Tobago
Re: a/c leak. Use or don't use stop-leak product?
Post by abscate » Fri Sep 14, 2018 7:51 pm
Dash a bit different. We might need a good DIY pdf from the VRD
1 SWMBO for 30 years
2 Volvos
3 VWs
4 Careers
5 cats/dogs/gears
6 Perfect Ladies in waiting
7 Drivers
8 Boats- with a big pointy metal thing on top
1999 V70 T5M 56 2005 V70 NA M56 VWs BMW
JimBee
Year and Model:
Been thanked: 14 times
Post by JimBee » Sat Sep 15, 2018 9:18 am
Two problems I can foresee:
running into broken dash mounts and really stuck springlock connectors at the firewall.
I haven't tackled broken dash mounts but have read a couple of tutorials and viewed the pics. I'm wondering if ABS sheet stock (which I have) together with JB Weld might be a fairly easy fix that's very durable.
I have a tool idea for the springlock connectors, having fought with them on a couple of cars. It would be great to have a quick and reliable way to make those disconnects.
Trinidad & Tobago
Post by abscate » Sat Sep 15, 2018 4:12 pm
Jim..if they get stuck we Dremel them off in 15 seconds
You can also either rebuild the dash mounts orbbutyl tape the dash
2 Volvos
3 VWs
4 Careers
5 cats/dogs/gears
7 Drivers
JimBee
Year and Model:
Post by JimBee » Sat Sep 15, 2018 4:39 pm
Ah, solutions. There's nothing like experience and a little Yankee ingenuity to get things done!
I did have a second thought about the stuck springlocks at the firewall. The problem getting those apart is with the pipes anchored to the coil you can't wiggle them loose. But, sure, cut them off, leaving enough of a stub to get hold of, and they're a lot easier to work apart! I did that with my dryer connector.
Trinidad & Tobago
Post by abscate » Sat Sep 15, 2018 5:24 pm
Start drenching the two 6mm hex head ALLEN bolts that hold the hard line in, right behind the right headlight
If those two come out, life is good and the hard lines, drier and compressor line will all come easily.
PB Blaster. Liquid Wrench. Kroil or zyour favourite
2 Volvos
3 VWs
4 Careers
5 cats/dogs/gears
7 Drivers
JimBee
Year and Model:
Post by JimBee » Sat Sep 15, 2018 10:01 pm
I had those all apart last summer, so they'll come out easily.
Trinidad & Tobago
Post by abscate » Sun Sep 16, 2018 4:07 am
Nissens is the Evap I’ve done in all the cars so far.
The kit list is
Nissens evaporator
2 sets of scantech oring kits
Receiver drier unless it got replaced with the conpresssor
, no need to do it again.
New orfice tube
2 Volvos
3 VWs
4 Careers
5 cats/dogs/gears
7 Drivers
JimBee
Year and Model:
Post by JimBee » Sun Sep 16, 2018 10:05 pm
I have 2 96 850's. Last summer, I went through both systems, adjusted their clutch gap (shim removed), cleaned up all the seats in the o-ring connections and installed new o-rings.
I need to do a close check on all those connections to make sure that's not where I'm losing pressure. That would be an easy fix. Receiver driers were also replaced last summer, so those are as good as new. The flex hose union on the burgundy is suspect, I think the other one is tight. Those unions got new o-rings, but the large nuts go on really hard and it's tough to know when they've bottomed.
The compressors are used units. I had them off, took out a shim so gap is exactly spec (.3 mm IIRC) flushed them with fresh oil and added spec'd amount. The one I plan to change also got a new pulley bearing.
Both cars have a little over 200k, so they probably need new evaporators anyway.
So a close inspection is next up.
Which one will I do? The burgundy GLT is the nicer ride of the two, so I'll probably tackle that one first.
So I'll need the coil, orifice tube. Doesn't the coil come with new o-rings?
Trinidad & Tobago
Post by abscate » Mon Sep 17, 2018 3:40 am
The orfice tube comes with orings , the Evap coil does not. The oring kit makes a valiant effort to include all orings but leaves you short. A couple of places use double orings and the guys at scantech are still on their first counting educational module.
If the evap are original and are still good you can probably fund this by submitting to the Guinness book of records.
2 Volvos
3 VWs
4 Careers
5 cats/dogs/gears
7 Drivers
wizechatmgr
Has thanked: 16 times
Been thanked: 39 times
United States of America
Post by wizechatmgr » Mon Sep 17, 2018 6:17 am
+1 on the count being off. At least two lines going to the evaporator have double o-rings.
1999 V70 XC AWD - ~172k miles
Who is online
Users browsing this forum: Cookeh, Eddystone, Google [Bot], Majestic-12 [Bot], Multiskilled, tardcart, wasaabi and 100 guests
