Greetings, I have an 06 S 40 T5 manual trans and it has an ignition switch problem. The other day I inserted the key and started the vehicle just as normal and after it started it quit immediately and everything was gone. Nothing electrical was working. Nothing. And the key will not go to the off position to be removed. The battery is fully charged and has good connections and grounds at the battery. My focus is twofold .
#1 , is this a key switch problem , or what might be going on ? A fusible link somewhere ?
#2 , what is the procedure for replacing the dash switch ? If I buy a used one will I need to get it programmed ? Can the programming be done anywhere other than Volvo ?
Any & all input will be much appreciated. I had Volvos back in the 70's but strayed from the fold. If I remember right it had a B40 engine.
Thank you for looking !
06 S40 ignition switch - Nothing electrical working. Key will not go to the off position. Topic is solved
LOL, Thanks for the help. Here is some insight for you. I found my problem. What happened is I lost electrical power at the connection for all the accessories right at the power bar coming from the positive battery post -- the one that feeds all the the accessories. As you know when you insert the key it makes a little buzzing noise & that somehow activates something inside the switch that allows it to release. So once I corrected the power problem the key released & everything is hunky dory. So here is the answer to my own issue. Hope that helps some other individual out there who is looking for an answer to an odd situation. Kudos !
I have a 2009 s40 (non turbo). Yesterday my wife was driving and the car cut off when she was in our neighborhood and she coasted into our street. The car will make a noise when trying to start, the lights all work, and the windows will go up and down. I tried to jump it this morning and got the same result, so I believe the battery is fine. I looked at the belt when it was being started and it did not move. I have read a few things and could point to alternator, ignition relay, or starter. Anyone know how to narrow it down?
Last year I had to replace the DIM, as it seems like this car has several electrical issues lately.
- 2083 Views
Last post by RLBOHNER38
- 1943 Views
Last post by vtl
- 1359 Views
Last post by RickHaleParker
- 4169 Views
Last post by rfm77555
- 4898 Views
Last post by Oly850
