New valve body, trans still unhappy
truher
Year and Model: 2001 V70 T5
Post by truher »
Hi everybody,
I replaced my AW55-50 valve body, after an episode wherein I lost all gears, but it seems not to have helped. All is good when cold, but when hot (fluid temp around 100 C), it has a hard time engaging any gears, and if i keep driving it, i'll end up in "limp" mode ("transmission service urgent"). I've tried TCM adaptation, and it just never figures anything out. It did succeed with the N-R garage shift, but not with anything else. Actually the adaptation got me into limp mode too. N-D, in particular, only engages if I rev fairly high, which of course results in a violent "clunk."
Any ideas? I could go measuring the various pressures; imagine sure the C-1 pressure is low, but I don't know what could cause that, other than damage in the clutch itself, which implies a problem i'm not prepared to fix myself.
[crosspost from swede, sorry]
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
The fluid should not reach 100C. Operating temp is 80C. Radiator fan is spinning?
Interesting you got the N-R adapted, that's the one I couldn't get, see towards the end www.youtube.com/watch?v=2RJyYRQxbZA
Condition of the replacement valve body?
I also think that if the transmission was going that bad in the past, there is wear inside the transmission itself, clutches, pump, etc, even a clogged filter from flowing particles.
truher
Post by truher »
Oh interesting. I'll double check the temperature. Valve body looked good, rebuild from valve body pros in Santa Clara.
