THESE STUPID DOOR LOCKS
shihabafi
Year and Model: 1995 850 Wagon
Has thanked: 50 times
Been thanked: 8 times
Post by shihabafi »
Alright, apologies for the crude title, but we've seriously gotta find some sort of permanent solution for this door lock.
When the lock actuator failed, I first got another one from the junkyard. When that failed, I took the one I had and ripped it apart, finding the problem, a bad motor, as I was expecting.
But a new actuator? At least a few hundred bucks. I don't have that kind of money.
I heard that there is some sort of temperature switch inside of the motor, but I've failed to open the metal casing. It's on there pretty good.
I've floated the idea of completely replacing this latch with the wire latch from the later S70 series and whatnot, but it would ruin the look of the interior once I put the door panel back on.
I'm pretty sure that this is the only model which Volvo put these in, so I'm at a standstill. What should I do?
rspi
Has thanked: 34 times
Been thanked: 72 times
Post by rspi »
I have never had a 850 door latch fail. Nearly 600,000 miles and counting.
joejoethedogfaceboy
Year and Model: 2012 XC60 3.2L
Has thanked: 2 times
Been thanked: 6 times
Post by joejoethedogfaceboy »
The motors from an S70 will be no better. The thermal resistor in the motor is a known and widespread failure point. I ended up tearing apart all 4 latch assemblies in my S70 and performed the fix from this video:
Not sure if the 850 has the same problem with the motors, but you need to be persistent with getting the metal tabs bent out to take the motor apart.
HTH
-Joe
2012 XC60 3.2
2012 S60 T5
2004 XC90 2.5T (SOLD 11/2017)
1999 S70 GLT (24hrs of Lemons bound...)
misha
Has thanked: 155 times
Been thanked: 432 times
Post by misha »
You must have some kind of problem which keeps blowing the motors.
Maybe the fuse is unapropriate rating...I would expect it to blow first before the motor.If it's just 5 A stronger it will not blow but it will burn the motor instead or melt the wiring...in the worst case.
Could be that wiring is shorted somewhere causing the motor to blow too.
I bought the car from new and never had any kind of problems except notorious fuel door lock,which was fixed looong time ago.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
Has thanked: 2199 times
Been thanked: 1852 times
If you are lucky the motor may not be burned out but the motor brushes may be worn. Try opening the motor up.
Look on line for a SAAB website that shows how to re-build a headlight wiper. It shows how to strip the motor. In fact the motor looks a lot like the ones used in headlight wiper motors and you used to be able to find them for sale on line. Using the info on the motor do a search and see if you can find the manufacturer or a similar motor.
Motors wear out but unless there is something causing the window to bind, they don't often fail like misha mentions.
