Hello
I've got a problem with my XC90 brakes that I can't solve. Started after I had swapped rims for another set of standard alloys( - but that is probably just a coincidence).
Initially felt like a warped disc when braking with uneven pedal feel. (Discs and pads only covered a few thousand miles)
The problem got worse with severe but intermittent judder at fairly low speeds, feeling like OSF (which had a new caliper a couple of years back). Also the ABS light came on and indicated OSF faulty. But it does feel like a mechanical fault rather than ABS operating in error. The car does not pull and normally the brakes are fine and stop the car well.
On inspection there were pad "grip" marks on the disc but all seemed fine.
Changed caliper fixings to avoid play. Even replaced disc retainer grub screw which had snapped when replacing (- but as wheel studs hold disc this should never have been the issue)
I'm now wondering if the problem is NSF?
Has anyone had a similar issue?
Thank you.
Brake judder
- RickHaleParker
- Been thanked: 977 times
Brake pad clips and retaining springs in place and in good condition?
Active
Past
Past
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
Osf for US guys means the front left wheel.
If the replacement rims are to blame, the small surface at the wheel hole where the lug is pressed against gets corroded. This corrosion causes greater friction - as opposed with a smooth surface - which affects the tightening torque. The result is an uneven torque on the 5 lugs which deforms the brake disc, causing brake pulsation. Simply clean the corroded surface with some steel wire sponge and tighten the lugs back again - you should feel each lug turns very smooth until it's fully tightened.
Against common sense, I would also recomment tightening the lugs in a clockwise pattern - as opposed to the common cross pattern - but use at least 4 steps to apply the torque.
Also when tightening don't fully lower the wheel to the ground, just enough so it doesn't turn, see this video www.youtube.com/watch?v=cH-f0Q1K5H8
But this would not answer the entire issue the way you describe it being intermittent, the abs light etc. I'm thinking something affected maybe the abs sensor. The pad marks on the disc also cause vibrations - usually cheap pads will dothis.
- RickHaleParker
Have you inspected Strut Mounts and Ball Joints?
Active
Past
Past
- 857 Views
Last post by RickHaleParker
- 1630 Views
Last post by steved1484
- 13 Replies
- 1141 Views
Last post by vtl
- 1530 Views
Last post by pranayama
- 14 Replies
- 3855 Views
Last post by instarx
