98' V70 doors hard to open? Help?
adrianleon0912
Year and Model: 1998 V70 GLT AWD
Been thanked: 2 times
Post by adrianleon0912 »
I few of my doors front and rear on my 1998 volvo v70 have handles that are pretty hard to pull and require some muscle. I owned this car for 3 months and had this problem ever since i bought it. Maybe needs lubricated but where? Could anybody help me?
jvl
Year and Model: 2006 V70 2.4D
Has thanked: 20 times
Been thanked: 8 times
Post by jvl »
Same problem on my '99 V70XC driver door, but not so big that it made me investigate (yet).
Curious for solutions as well!
And good luck to adrianleon ofcourse.
1999 V70XC - Sold at 250K miles
2006 V70 2.4D - bought at 190k miles and going strong
Has thanked: 2197 times
Been thanked: 1850 times
Most likely just need a good lube. One of the things I do when I buy a new to me old car. In the case of the Volvo P80, make sure you have some spare door card clips as they will likely break a bunch when you remove them at this age.
Grease the lock mechanism on the back of the door. If they are as tight as you say, try spraying them with a spray lube or WD40. Then let them soak for a while and then carefully work the locks up and down with the door open. If you get no improvement, then the door covers need to come off to get to the door mechanisms to get lube into those as well as the lever assemblies before you break anything expensive. While in there make sure you lube the door limit straps and the hinges.
