1996 960 Brake Shift Lockout
correllkp
- Year and Model: 1995 850, 1996 960
- Been thanked: 3 times
Hello all. Often times, especially when the cabin is hot, the shifter will not shift out of park. At first I though it was the brake shift lockout switch. However, when this happens I can use the override button to put the car in drive but the car does not have any dashboard power (no lights), headlights don't work, turn signals don't work, and power windows don't work. If I use the override switch to put into gear and drive around for a while the power to the above does come on. I am thinking this is not the brake shift lockout switch...any ideas what it could be?
correllkp
Found the problem from one of Robert’s videos...interlock switch on the steering column has a weak spring. When key is turned to turn car on it doesn’t return all the way back to where it should be...just have to move the key back a hair and all works fine. The part is about $50 and from the video shouldn’t be long to replace...20 min or so.
- 675 Views
Last post by carguy124
- 1062 Views
Last post by PS78
- 1695 Views
Last post by Legofan
- 793 Views
Last post by Mr. Weekend
- 3217 Views
Last post by volvolugnut
