Poor range remote key fob s40
Civeciv123
Year and Model: S40 2006 1.6D
Post by Civeciv123 »
Hi guys, I've a problem with my volvo. Since I bought it has always had this problem, the keys (both) work only very closely. I've already changed the batteries but it's the same. I think therefore that it depends on the car and not on the keys. Any ideas? Thank you!
RickHaleParker
Been thanked: 978 times
Post by RickHaleParker »
About 50 yards (45.72 meters) is the correct range.
Check the car's battery voltage with the engine off and after it has sat for 30 minutes.
The external antennas are in the door handles and the rear bumper.
Approach the car from different directions see if it makes a difference. If it does make a difference it is most likely one or more of the antennas or antenna wiring.
If it does not make any difference which direction, it is most likely the Keyless Vehicle Module (KVM) or the wiring to the KVM.
Active
Past
Civeciv123
The distance is about 2 meters or less .. I noticed, however, that from the top with the car in front increases by a few meters .. Would you have some guide or scheme for the antennas? The car battery is also new .. Thanks!
jtopiso
Year and Model: 2009 C30 2.0i
Been thanked: 3 times
Post by jtopiso »
Does this happen always, on any location, or you are testing on the same place? It could be a jammer nearby interfering your remote's signal (if you are close to a police station, a government building, etc)
Civeciv123
It happens in every place. I think the problem is due to the antennas or the ECU of the car..
