Here's what I know...
Previous to this week, I haven't used the Cruise Control in maybe 2 years.
A few weeks ago I had the battery changed to a brand new one, no issues. I've driven the car over a 100 miles since then, 30 in town, 70 highway. Oil changed recently too.
A week ago I had spark plugs changed- engine is no longer coughing.
Drove at 65 mph l last week for an hour- used cruise control (CC) no issues.
Driving back on a second day, I engaged the CC at the same speed, no issues, then went over a small bump, the car began to decelerate due to slope of the road, the CC had disengaged.
During this drive it would go on/off at the same rate of speed, not always due to a bump on the road.
Also, following day, the CC wouldn't engage at all. I gave up.
I don't have any engine/dashboard lights on or blinking. Nothing blinked when I went over the few small bumps.
What should I be looking for, suspects causing this error? I'm bringing it to my Volvo mechanic, he's from Sweden this is all he works on, never been wrong before.
Can a computer diagnostic reveal the issues?
It's a 1995 so I venture to guess at some point some things may just break. I'm the only owner too.
Cruise Control Intermittently working-- stumped
- WhatAmIDoing
- Has thanked: 104 times
- Been thanked: 105 times
Cruise control is vacuum controlled. Would have to test pump (under the battery). Probably need to replace the vacuum lines. There's also a diaphragm that can break. Plus there are switches under the dash near the brake and clutch (tell CC whether you engage brake or clutch) that may need to be adjusted. That's about the extent of my knowledge. This is something I've been meaning to fix for 2 years now.
Knows enough to be dangerous
viper69
- Year and Model: 850GLT 1995
- Has thanked: 77 times
- Been thanked: 2 times
I wonder how much this is going to cost..jeez
Volvo 850 GLT 1995
5 Speed Manual transmission
122,500 miles and barely broken in
'82 Volvo DL Wagon, 4 speed manual
'77 Saab 99 EMS, 4 speed manual
- Been thanked: 4068 times
Very little for old vacuum hose replacement. 20 year old rubber hoses all pretty much need replacing.
JimBee
- Has thanked: 33 times
- Been thanked: 43 times
I looked this up recently, also, due to same symptoms in my 96 base 850. I haven't solved mine but I will explore one suggestion: the control module in the fuse box. Somebody confirm this, I think it's the one next to the headlight module. In that post I think someone suggested cleaning the contacts first. If that doesn't work I don't know if there's a way to test it off the pins.
I just found the link you need to troubleshoot all the parts of the cruise system. I'll be using it too. Read down the thread, erik posted the link:
viewtopic.php?f=1&t=65680
precopster
- Year and Model: Lots
- Been thanked: 128 times
- WhatAmIDoing
The vacuum lines are a pretty good bet and cheap to replace. The switches for the clutch and brake are also an easy place to start. I don't know if there is any record of the CC pump or relay ever going bad, but those should be easy to test. Also should check the fuse for CC. Some users have reported the wiring for CC failing in the turn signal lever.
Edit:
Edit:
This is a good guide. Does anyone know if there are difference for CC between a 95-96 and a 98?JimBee wrote: 29 Sep 2018, 20:13 I just found the link you need to troubleshoot all the parts of the cruise system. I'll be using it too. Read down the thread, erik posted the link:
I think the P80s are all the same, smirks from the 1999- crowd with fully electronic cruise control with no parts to fail notwithstanding...(basking in the warm glow of the ETS light)
precopster
Those Cruise modules date back to the early 80s. I had the same one on my 1989 turbo 740; not exactly miniaturization on the board.
The cut-out over a bump suggests an electrical contact problem.
markone
- Year and Model: 2007 V70
- Has thanked: 21 times
- Been thanked: 14 times
I had a similar issue with my ‘97 850 CC. Turned out it was the battery sitting atop, and pinching, the vacuum line.
2006 V70 NA/manual trans, 165k
2007 V70, NA/manual trans, 143k miles
2023 BMW X1, 29k miles
2018 Jeep Grand Cherokee LTD, 91k miles
2007 Malibu Response LXi, Ebony/white, 340 hp, 395 hours
1997 850 Sedan NA, manual trans, sold at 330k miles
1998 V70, NA/manual trans, sold at 365k miles
- 1123 Views
Last post by Stoneworks
- 5275 Views
Last post by THeOldMan
- 697 Views
Last post by howardc64
- 32 Replies
- 9811 Views
Last post by zhenya
- 716 Views
Last post by Denwiley
