fill reservoir too high, it leaks out of the passenger side headlight wiper
WhatAmIDoing
Has thanked: 104 times
Been thanked: 105 times
Post by WhatAmIDoing »
If I fill my reservoir too high, it leaks out of the passenger side headlight wiper. Do you know where it's leaking?
Clemens
Has thanked: 498 times
Been thanked: 228 times
Post by Clemens »
my reservoir overflows somewhere else when filled all the way up. since it is quite big, i just don't fill it all the way anymore. do you park your car on a steep driveway with the front facing down? if so, your problem is problem might be just that. if the headlight nozzle is lower than the reservoir it will leak.
1996 855 R,
2010 V70 D5,
voltech1
Year and Model: 2000 V70R
Has thanked: 2 times
Post by voltech1 »
There is a check valve behind the passenger headlamp that is leaking. You can find the washer hose running between the headlamps. If you gently pull the hose going behind the passenger lamp it should show itself. The valve will need replacement.
96 855 turbo 235k
00' v70r 156k w/blown motor
