Hello all,
Looking for some suggestions here. I did a dash mount repair, but did not disconnect the battery before taking unplugging the air bags (steering wheel and passenger side) Of course I got the SRS light.
I purchased the 10 in one tool (Chinese from eBay). It did in fact reset the service light fine, but the light did not go out when I reset the SRS light. It indicated to click "OK" to reset the light, but the light remained illuminated.
Any ideas??? Thanks
John
SRS light after dashboard repair
- Been thanked: 4071 times
You need a decent scanner to do the SRS reset, or pay the dealer tax.
The AUTEL 500 and up series has been tested successfully here.
- Has thanked: 316 times
- Been thanked: 531 times
What tool did you purchase? If it was Vol-FCR, it seems to work best with an FTDI VAG-Com cable, and you need to make sure you have the correct drivers installed and it's set to COM1.
I don't know that anything else will work for an 850.
- Chuck W
- Year and Model: 97 854 T5
- Has thanked: 97 times
- Been thanked: 340 times
My Autel EU702 works on my '96 and '97 850s. I've reset the SRS light a couple of times.
Hers an amazon link
https://www.amazon.com/EU702-Code-Scann ... UTEL+eu702
I might be down on Long Island next week if you want to try a meet and g SRS eet
Nice meeting you today , J.
Unfortunately, I couldn’t get my AUTEL 8xx to clear the SRS code.
Anyone got Vol FCR in Queens, LI area?
- Has thanked: 2207 times
Did you re-seat the passenger side airbag connector fully if you had it disconnected.
Also the airbag in the steering wheel can cause issues if the clock-spring was damaged or re-seated correctly. Either could be the real issue the SRS light is not re-setting
