1995 volvo 850 starting issue
conversesmith0601
Year and Model: 2010 xc60 t6
Post by conversesmith0601 »
This isn't so much of an issue, but rather something I would like to explain to my friend who is buying the car from me. Ever since I've had the car (5 years), when you start the car, the ABS light comes on and the cars headlights or blinkers wont work. The ABS light turns off and everything works as it should once you turn the key towards you about half an inch.
Does anyone have any clue why this might happen?
Thanks!
Has thanked: 1611 times
Been thanked: 4072 times
It sounds like the classic 'ignition switch, electrical part' failure
Do your friend a solid and buy a new one from FCP IPD or EEuro and put it in, following this thread
viewtopic.php?f=1&t=64352&p=332883&hili ... ch#p332883
About $50 fix,less if you value your friendship less and don't mind him/her getting stranded in a year
conversesmith0601
that wouldn't make sense, because that was already replaced a few years ago.
Aftermarket parts last about that long if they aren’t Volvo or OEM manufacturer
misha
Has thanked: 155 times
Been thanked: 432 times
Post by misha »
conversesmith0601 wrote: 03 Oct 2018, 09:14 that wouldn't make sense, because that was already replaced a few years ago.
Abscate is right....ignition switch can be the only cause of this.
What i don't quite understand is...was the problem solved with replacement or did this re-appeared again after a while?
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
