Brake fluid low warning
Mr. Detail
- Year and Model: 2002 V70 N/A
- Has thanked: 157 times
- Been thanked: 6 times
Heh guys. I am starting to wish I had repaired my old '98 S70, so I don't have to see that darn message board thing in the lower left corner of the dashboard. Anyway it has been giving me an URGENT warning about low brake fluid yet when I went under the hood last evening and checked the reservoir, it was completely full. Do I need to be concerned? Not sure what else could be wrong.
- June
- Has thanked: 523 times
- Been thanked: 261 times
Check the float in the master cylinder reservoir that it floats and the electronic connector is properly making contact. June
My Volvo cars owned
1989 740 GLT ordered
1996 960 ordered
1998 V70 GT dealer stock car
2002 S80 T6 ordered totalled
1996 960 ordered
Mr. Detail
June, thanks for you response. How do I check the float when there is no real access? I unscrewed the cap and then witnessed this slotted plastic insert. Is the float internal to the reservoir? Can you buy a new float alone if necessary?
- Been thanked: 4071 times
When you pull the cap the float comes with it, unless the P2 is completely different?
If you,didn’t undo an electrical connector to remove the cap, you might have found the problem
On edit, I am idiot. P2 is different
- June
P2 has a stand alone cap and the connection is part of the reservoir. Here is my S80s fluid reservoir. Looks like one screw type fastener holds the reservoir to the master cylinder and the float may be felt with a paperclip straitened then poked through the narrow opening inside the reservoir carefully, otherwise the reservoir needs to come off and you may as well put a new one on. Juneabscate wrote: 04 Oct 2018, 07:08 When you pull the cap the float comes with it, unless the P2 is completely different?
My Volvo cars owned
1996 960 ordered
1996 960 ordered
OMG....who came up with that design. Please don’t tell me I have that on my P2.....
- June
abscate wrote: 04 Oct 2018, 15:04 OMG....who came up with that design. Please don’t tell me I have that on my P2.....
My Volvo cars owned
1996 960 ordered
1996 960 ordered
- 1322 Views
Last post by oragex
- 3523 Views
Last post by Krons
- 700 Views
Last post by aspireToRepair
- 1105 Views
Last post by weshamm
- 193 Views
Last post by Evolvo850B
