Hi Guys, long time reader, first time poster.
I am an independent auto broker that specializes in Volvo's and me and my Volvo tech are perplexed on an 2008 S80 T6 I have.
The master power window switch will not work intermittently (works more than doesn't), when it stops I can slam the door and it works again. My tech has 20 years Volvo dealer experience, and we are both stumped. So far I have replaced the switch with a new one. We also removed the door and pulled the wires in the harness out as far as we could and did not find any broken wires (there is a plastic tie that Volvo used and the wires commonly break at that tie). I really don't want to pay exorbitant diagnostic fees or even replace the door wiring harness, so before I go down that road just wanted to see if anyone has experienced this?
By the way, I have repaired countless Volvo's I have sold myself, thanks to this forum. A treasure trove of information. Thanks
S80 Master Power Window switch
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
Have you guys tested the wires for continuity with a multimeter? Like one by one while twisting bending the harness in some places. The wire may be almost broken inside the jacket.
Also thinking at some water leak onto the switch unit from inside the door panel, the door card panel would show some darker areas (tough it may feel dry if no recent rain). The water strips and seals on these cars don't do that well at 10 years old.
MrBreeze
- Year and Model: 2010 Volvo S80 3.2
Have not tested the connections for continuity yet. Will try this weekend.
Forgot to mention all the individual door window switches work fine, so problem is confined to drivers door.
When I changed the master switch I saw nothing that made me think water leak, will check again.
halseyfolk
- Year and Model: V70 3.2, 2008
Any chance you could help with how to remove the door panel on 08 models? The clips went away and not wanting to break anything in ours we are about to repair.
Thanks!
Thanks!
- 1464 Views
Last post by beigg
- 1717 Views
- 18 Replies
- 3790 Views
Last post by FLXC90
- 1019 Views
Last post by wizechatmgr
- 3940 Views
Last post by cn90
