Thread to document rework of parking brake, starting with console removal.
Couple of tricks here on plastic removal.
Tools
Torx 20 bitfor console screws
Spudger for plastic
Pliers for shift lock ring
Console held in with four Torx screws
Two in front after you lift shift console plate
Two in rear compartment after the rubber mat is lifted
Shifter is released by pulling lock ring down, the popping shift handle up, cover and boot then slides over
Two side pieces on console are released by inserting a coin into the slot at th e rear end, then sliding the pieces forward to release.
One electrical disconnect at rear for 12 V output
Brake handle boot pops out , up and over
The brake adjust is a simple 10 mm hex bolt
I set the handle to 4 clicks, then tightened bolt to full brake action. On release, both wheels spun freely
2005 V70NAM56 Console Parking brake rework
- Been thanked: 4068 times
Picture Bank
Anyone notice the PM trick that can save you hours of heartache, and many,many dollars of parts cost?
Its in the second to last photo
Answer: new bleeder screws if they are more than 5 years old in salt climates,replace them with real Volvo ones.
Finished this job today by lifting console to reconnect rear 12VDC accessory plug
- 2282 Views
- 915 Views
Last post by sleddriver
- 13 Replies
- 5642 Views
- 14 Replies
- 5879 Views
Last post by V70r carbon
- 3248 Views
Last post by BlackBart
